highlander Posted December 14, 2008 Share Posted December 14, 2008 OK. Car: 05 LGT 5 MT AP: v1.5 MAP: eTune from known vendor Mods: UP/DP/MP/CBE AEM CAI Perrin TMIC Prodrive EBCS ACT clutch/LWFW LW crank pulley GFB BOV Logged car after new eTune - found no boost. Reloaded original eTune - found boost, but map not set for CAI, TMIC, or EBCS Loaded yet another eTune map and car boosted fine (warm weather). Twice now the car has thrown P0244 in 35 degree ambient or less, third gear WOT, 3-4kRPM. Overboosted to about 22psi if my memory serves (hard to look diplay where it is mounted when you are distracted by the CEL engagement). Options: 1. Retune after logging in cold air? Gonna be hard to complete as the CEL will kick in during logging runs. Hints on how to do this appreciated. 2. Remove EBCS, reinstall OEM BCS and retune? I'm sure the EBCS was the original sticking point with the eTune as the vendor had tuned for the other mods frequently. I went with the EBCS as it offered more control options, especially if I uprgaded to a different turbo with an EWG. AFAIK, there are no local shops doing AP tuning in central Va. which is why the eTunes (plus the cost savings over dyno time). I understand the mechanics of the car, but I am a tuning virgin when it comes to the ECU controlled options. Not trying to set the world record, just have reliable all weather performance when I want it. Vir Est Fatum Ut Perficio Concepta Suus Progenies. - Man is destined to fulfill the capacity of his lineage (i.e. Darwinism) Link to comment Share on other sites More sharing options...
rao Posted December 14, 2008 Share Posted December 14, 2008 If the tune didn't account for the EBCS you are lucky that the only problem you are having is some overboost in the cold. The Wastegate duty control solenoid tables need to be adjusted - not hard to do but very necessary. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
highlander Posted December 14, 2008 Author Share Posted December 14, 2008 The car was eTuned for basic Stg 2 mods. I added the TMIC, EBCS, and CAI and purchased a new eTune for those mods. The new map didn't boost. I reloaded the first eTune just to verify no leaks and the car boosted. Sent logs of both back to vendor and received another new eTune map. Car boosted normally then (in warm temps). Now getting overboost in cold air. I don't recall this occuring last winter (retuned in October 07), so I am wondering if I have a mechanical issue keeping the WG from functioning properly. Vir Est Fatum Ut Perficio Concepta Suus Progenies. - Man is destined to fulfill the capacity of his lineage (i.e. Darwinism) Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 14, 2008 Share Posted December 14, 2008 The car was eTuned for basic Stg 2 mods. I added the TMIC, EBCS, and CAI and purchased a new eTune for those mods. The new map didn't boost. I reloaded the first eTune just to verify no leaks and the car boosted. Sent logs of both back to vendor and received another new eTune map. Car boosted normally then (in warm temps). Now getting overboost in cold air. I don't recall this occuring last winter (retuned in October 07), so I am wondering if I have a mechanical issue keeping the WG from functioning properly. Were you running the Prodrive and new etune map last year? From your description, it sounds like you weren't. There is a WGDC IAT compensation table that needs to be adjusted. Link to comment Share on other sites More sharing options...
highlander Posted December 14, 2008 Author Share Posted December 14, 2008 Had a Stg2+ eTune from 2006-4/07. Installed TMIC, EBCS, and CAI with new map from vendor to support mods. Identified boost issue in Fall of 07 which was something in the map. (original 2+ map boosted, new map didn't with new parts on both) Logged for vendor and received new map. Didn't notice any issues last winter. Now twice it has overboosted in cold. Question: Would a kinked or obstructed vacuum line in the boost control circuit cause this symptom? How about an open vacuum line somewhere? Just thinking it through; trying to rule out mechanical/physical issues before tuning ones. Vir Est Fatum Ut Perficio Concepta Suus Progenies. - Man is destined to fulfill the capacity of his lineage (i.e. Darwinism) Link to comment Share on other sites More sharing options...
highlander Posted December 15, 2008 Author Share Posted December 15, 2008 Am I in the neighborhood with the kinked hose? Vir Est Fatum Ut Perficio Concepta Suus Progenies. - Man is destined to fulfill the capacity of his lineage (i.e. Darwinism) Link to comment Share on other sites More sharing options...
holyjoetart Posted December 15, 2008 Share Posted December 15, 2008 It has to do with the cold air. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 15, 2008 Share Posted December 15, 2008 The things you mentioned would cause warm weather overboost problems as well. Link to comment Share on other sites More sharing options...
highlander Posted December 15, 2008 Author Share Posted December 15, 2008 OK. I realize the cold air is the culprit if nothing has changed. I'm just trying to rule out other potential causes as I do not recall having these issues last winter with the same tune/parts. Just thinking out loud.... Thanks for everyone's advice. I have contacted a tuner familiar with my current map and he assures me that he can tune out the cold air issue if that is the cause. Vir Est Fatum Ut Perficio Concepta Suus Progenies. - Man is destined to fulfill the capacity of his lineage (i.e. Darwinism) Link to comment Share on other sites More sharing options...
qikslvr Posted December 18, 2008 Share Posted December 18, 2008 The overboost issue is more than likely due to the WGDC atmospheric/AIT compensation tables in the base map. Most of the e-tunes don't get adjusted for the cold weather. I'll post up a screen shot of the table(s) in question shortly. Let's kick this pig! Link to comment Share on other sites More sharing options...
