Tuned200 Posted December 2, 2008 Share Posted December 2, 2008 sounds like a cracked oil feed line thats your worst possible situation honestly it sounds like residual oil from a tech being sloppy most likely. They did a clutch job maybe 3K miles ago as well. I guess im going back up there and will have them investigate it.... Link to comment Share on other sites More sharing options...
SSN666 Posted December 2, 2008 Share Posted December 2, 2008 Just mount the fumoto valve and stop worrying about washers. Amen. Great device. K&N HP1008 filter. Mainly because it has a cap on it that allows the use of a 1" socket to remove it. Link to comment Share on other sites More sharing options...
spect2k Posted December 19, 2009 Share Posted December 19, 2009 Sorry to pull up an old thread, but now that it's been a year, has anyone seen a problem or heard of a problem with the new BLUE OEM filters? Link to comment Share on other sites More sharing options...
Pataker Posted December 20, 2009 Share Posted December 20, 2009 I love my Bosch... never had an issue on any of the cars that I have had them on Link to comment Share on other sites More sharing options...
Scotty Posted December 20, 2009 Share Posted December 20, 2009 I've gone through quite a few of the blue ones with no problems. They are made by Honeywell. Link to comment Share on other sites More sharing options...
pillboy Posted December 20, 2009 Share Posted December 20, 2009 I've gone through quite a few of the blue ones with no problems. They are made by Honeywell. Not that that makes them great. Honeywell (the old Allied Signal) also makes Fram. Honeywell has whored their name out in the past few years on a wide variety of products. I have a couple friends that work for Honeywell. Allied Signal is trading on the reputation of the Honeywell name after the companies "merged" a few years ago. It is still ugly. Link to comment Share on other sites More sharing options...
ehsnils Posted January 2, 2010 Share Posted January 2, 2010 I did an oil change today and I did mount the Mahle/Knecht OC195 filter, which is a third-party replacement for the Subaru original filter. I don't predict any problems with this filter, but I went into the Mahle web site and found out that this filter is also used on a variety of vehicles. For some reason I think that our oil filters are small, but obviously they are able to cope with the normal conditions. I just wonder if there is a list of alternative filters for special conditions. A larger filter should be able to have a larger filter area, which means lower pressure fall and ability to catch more dirt before the bypass valve takes over. And as long as it fits on the thread and gasket and inside the headers there shouldn't be a problem as most cartridge filters works the same way. And I did also find out today that the oil plug has the same diameter/thread as the oil filter. That may prove useful in cases where you get stuck in an awkward situation needing a compatible oil filter. Link to comment Share on other sites More sharing options...
Guest Posted January 2, 2010 Share Posted January 2, 2010 And as long as it fits on the thread and gasket and inside the headers there shouldn't be a problem as most cartridge filters works the same way. Absolutely not true. 99% of aftermarket filters do not meet Subaru's spec for the bypass valve spring rate. Subaru filters use unusually high tension bypass valve. I am only aware of a single Purolator filter meeting the spec (don't recall the part number, but that should be easily googleable). Otherwise one should use only OEM filters. Link to comment Share on other sites More sharing options...
