ysrdubcf Posted November 24, 2008 Share Posted November 24, 2008 I recently replaced my low beams with Silvania Superstar Ultras and disabled the DRL's at the same time. The new bulb were great, however, I've been noticing the past week or so that they don't seem as bright as they used to but thought maybe it was just me. Then the other night I went to hit the high beams and both of those out completely! I haven't checked bulbs or fuses yet, haven't had time, but does this sound familiar to anyone.....?? Relay?? Link to comment Share on other sites More sharing options...
LGT Dave Posted November 25, 2008 Share Posted November 25, 2008 How did you disable your DRL's? Link to comment Share on other sites More sharing options...
ysrdubcf Posted November 25, 2008 Author Share Posted November 25, 2008 I disabled the DRL's by unplugging the white plug on the fire wall under the dash as described in the "Free Mods" section. So I checked bulbs and fuses last night and everything was fine. Just for sh*t's I plugged the DRL plug back in and everything worked again. So how did everything stop working all of the sudden?? When I first disabled the DRL's all lights worked as they should have. Link to comment Share on other sites More sharing options...
jedraz Posted November 25, 2008 Share Posted November 25, 2008 You need to leave the plug connected and remove the one wire, blue with black tracer everything will work except the DRLs, I just did this. http://www.legacygt.com/forums/showpost.php?p=913328&postcount=67 Link to comment Share on other sites More sharing options...
LGT Dave Posted November 25, 2008 Share Posted November 25, 2008 You need to leave the plug connected and remove the one wire, blue with black tracer everything will work except the DRLs, I just did this. http://www.legacygt.com/forums/showpost.php?p=913328&postcount=67 +1 Subaru made changes on the '07 models and just unplugging the white plug ended up disabling the high beams and fog lights along with the DRL's. You have to disconnect the blue/black wire (either cut it or remove it from the connector with the instructions in the post above) and plug the white connector back in. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 26, 2008 Share Posted November 26, 2008 May be they haven't fixed that problem yet. Seems the only bulbs you can use are from the dealer. There's a link here somewhere. My 05 kept burning the Silver Stars. Years ago I bought the $21.00 Subaru bulbs and have no more problems. http://legacygt.com/forums/showthread.php?t=12570&highlight=head+lights 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
