grimbeaver Posted February 13, 2005 Share Posted February 13, 2005 What type of glue is used to stick the letters on the trunk? Or more specifically, what type of glue do i need to buy if I want to stick letters back on my trunk? Link to comment Share on other sites More sharing options...
rao Posted February 13, 2005 Share Posted February 13, 2005 3M makes trim adhesive that does the job well. Any decent auto parts store will have some. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
SC GT Posted February 13, 2005 Share Posted February 13, 2005 IMO, if you ever want to put them back on, you should buy new ones from the dealer. Link to comment Share on other sites More sharing options...
tsyGT Posted February 15, 2005 Share Posted February 15, 2005 Bubble gum. Were you going to put all the badges back on? I'm still playing with putting the GT back on the trunklid, kinda like a BMW. But I'm enjoying the clean stealth look for now. tom tom Link to comment Share on other sites More sharing options...
SFGR415 Posted February 15, 2005 Share Posted February 15, 2005 double sided tape Link to comment Share on other sites More sharing options...
fbi012 Posted February 15, 2005 Share Posted February 15, 2005 double sided tape ur kidding, right? Link to comment Share on other sites More sharing options...
red beast Posted February 15, 2005 Share Posted February 15, 2005 rao is CORRECT! i used some double sided tape to hold a phone lifter on a the side of a phone. works great. take a look around 3M this is also how you hold the eyelines on. http://solutions.3m.com/wps/portal/_l/en_US/_s.155/116943/_s.155/8451 and the video is informative. Link to comment Share on other sites More sharing options...
ScottBlair Posted February 15, 2005 Share Posted February 15, 2005 3M trim adhesive is all you need.... Link to comment Share on other sites More sharing options...
John M Posted February 15, 2005 Share Posted February 15, 2005 Yep, but good luck ever getting that stuff off if you ever want to again! Link to comment Share on other sites More sharing options...
grimbeaver Posted February 16, 2005 Author Share Posted February 16, 2005 Yep, but good luck ever getting that stuff off if you ever want to again! oh i don't like the sound of that... Link to comment Share on other sites More sharing options...
John M Posted February 16, 2005 Share Posted February 16, 2005 3m trim adhesive is permanant. It's more for hood ornaments & stuff, or badging that you never want to remove again. Link to comment Share on other sites More sharing options...
grimbeaver Posted February 16, 2005 Author Share Posted February 16, 2005 so what do i get if there is a chance i will remove it? Link to comment Share on other sites More sharing options...
Scooter Posted February 18, 2005 Share Posted February 18, 2005 Relax, everybody. The acrylic foam core 3M double-sided tape (not the trim adhesive and not the clear scotch tape) has a near monopoly on the business: badges, bodysides moldings, even some big claddings and wheelflares on SUV's. It's available at any automotive store (it's got a red lining) and is the product that the badges came with in the first place. It's the right thing to use, and it is NOT permanent. I believe the Subie badges are the 1.1mm thickness, but I'll check that and get back to you. The hard part will be cutting it to fit the badging letters - Subaru buys it as a die-cut piece that matches perfectly. I agree that it would probably be easiest just to buy a new badge, which will have the tape on it already, but there's no reason you couldn't do it yourself, either. Make sure you clean the sheetmetal before applying the badging: 3M recommends a quick alcohol wipe, and it also helps if the surfaces are at room temp or above. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
iyamdman Posted February 21, 2005 Share Posted February 21, 2005 Now, for a really dumb question. What is the best way to de-badge the car? Just rip them off?!?!? Link to comment Share on other sites More sharing options...
rallispec Posted February 21, 2005 Share Posted February 21, 2005 Now, for a really dumb question. What is the best way to de-badge the car? Just rip them off?!?!? dental floss in a 'saw' motion between the badge and car... then go back and clean up the gunk with some of the goo remover. brute force prying works too, just be carefull or you could scratch your car or bust the crap out of your fingers. Link to comment Share on other sites More sharing options...
SBT Posted February 21, 2005 Share Posted February 21, 2005 Now, for a really dumb question. What is the best way to de-badge the car? Just rip them off?!?!? Got a good heat gun or a heavy duty hair dryer? Try heating up the emblem first and then use dental floss to get it started. Should basically just "peel off" at that point. Then clean up the individual attachment spots. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
racerdave Posted February 21, 2005 Share Posted February 21, 2005 Following those guidelines, I was amazed at 1) how easy they came off and 2) how good SWP looks debadged. Link to comment Share on other sites More sharing options...
rallispec Posted February 21, 2005 Share Posted February 21, 2005 Following those guidelines, I was amazed at 1) how easy they came off and 2) how good SWP looks debadged. i havent debadged this car yet -- but probably will be doing it soon --- the pics i've seen so far are definitely good looking. Link to comment Share on other sites More sharing options...
SBT Posted February 21, 2005 Share Posted February 21, 2005 Following those guidelines, I was amazed at 1) how easy they came off and 2) how good SWP looks debadged. Wait till you see it debadged and tinted. Dayang...that thing looks good. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
racerdave Posted February 21, 2005 Share Posted February 21, 2005 Wait till you see it debadged and tinted. Dayang...that thing looks good. SBT Yeah, I gotta work on that tinting... Link to comment Share on other sites More sharing options...
tsyGT Posted February 22, 2005 Share Posted February 22, 2005 Now, for a really dumb question. What is the best way to de-badge the car? Just rip them off?!?!? Search. Oh, here it is. http://legacygt.com/forums/showthread.php?t=1175 tom tom Link to comment Share on other sites More sharing options...
