ncmx5 Posted November 11, 2008 Share Posted November 11, 2008 just wondering if anyone had any references or experience in doing this conversion. is it a direct front fit? and most importantly are there any benefits? Link to comment Share on other sites More sharing options...
GTkansan Posted November 11, 2008 Share Posted November 11, 2008 lazy subscribe. Id love to hear this answer. Link to comment Share on other sites More sharing options...
DiscoWagon Posted November 11, 2008 Share Posted November 11, 2008 Yes direct fit, better pedal feel. Link to comment Share on other sites More sharing options...
pansontw Posted November 12, 2008 Share Posted November 12, 2008 Sorry, could you be more specific as which model year of wrx?? Thanks Link to comment Share on other sites More sharing options...
ncmx5 Posted November 12, 2008 Author Share Posted November 12, 2008 well i bit the bullet and bought one. it came from MY00 wrx. the guy said the calipers were the same until MY05 model. Link to comment Share on other sites More sharing options...
N.sane Posted November 12, 2008 Share Posted November 12, 2008 Interesting, let us know how it turns out. How about the rears? Link to comment Share on other sites More sharing options...
BrownBoy Posted November 12, 2008 Share Posted November 12, 2008 this would make finding some aftermarket brake pads MUCH easier. Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted November 13, 2008 Share Posted November 13, 2008 When I had my 2.5i. I upgraded to the front wrx 4-pots along with LGT drilled/slotted rotors and some hawk pads. Trust me it had a nice feel and bite I was also going todo the H6 upgrade(ordered the adapter brackets,) in the rear ,but traded too a lgt before I had a chance too. Link to comment Share on other sites More sharing options...
N.sane Posted November 13, 2008 Share Posted November 13, 2008 Damn, looks like my mod list will be extended now lol Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted December 9, 2008 Share Posted December 9, 2008 bump, can we bring up the brake discussion again, plz? Link to comment Share on other sites More sharing options...
N.sane Posted December 9, 2008 Share Posted December 9, 2008 ^+1. our stock brakes are poop lol. And the rear rotors look so tiny! Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted December 9, 2008 Share Posted December 9, 2008 Yeah really noticed that when I pulled up beside a Merc at the gas station the other day. Link to comment Share on other sites More sharing options...
N.sane Posted December 9, 2008 Share Posted December 9, 2008 well, it looks like WRX 4-pots are the choice for the fronts, I wanna find out if theres any direct replacement calipers/rotors for the rears? Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted December 9, 2008 Share Posted December 9, 2008 What is this '4-pot'? I'm a noob. Link to comment Share on other sites More sharing options...
naimouasta Posted December 9, 2008 Share Posted December 9, 2008 these guys Link to comment Share on other sites More sharing options...
WhatV8 Posted December 9, 2008 Share Posted December 9, 2008 What is this '4-pot'? I'm a noob. 4-pot = 4 piston caliper They give a better 'feel' to the brake pedal, even out the pad wear on the individual pads and give you a larger choice of aftermarket brake pads to better match to your driving style/needs. Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted December 9, 2008 Share Posted December 9, 2008 They are a direct fit and you can use lgt rotors with them. Link to comment Share on other sites More sharing options...
N.sane Posted December 10, 2008 Share Posted December 10, 2008 Anybody know if it's a direct fit for the rears as well? Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted December 10, 2008 Share Posted December 10, 2008 Would LGT calipers be considered an upgrade for the 2.5i? I need to jump on this because my rotors and warped and my pads are shot. I was just thinking about upgrading to a LGT brake setup, would everything line up correctly? Link to comment Share on other sites More sharing options...
06Limited Posted December 10, 2008 Share Posted December 10, 2008 LGT calipers are a bigger upgrade than the wrx 4-pots and by the looks of it they go for about the same price. They should also line up. Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted December 10, 2008 Share Posted December 10, 2008 Going for a set of 4-pot calipers for the fronts, LGT calipers/brackets for the rear, and DBA slotted rotors all around. The 4-pot calipers do not require mounting brackets I assume? Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted December 10, 2008 Share Posted December 10, 2008 They are a direct fit and you can use lgt rotors with them. Did you need brackets when you put in the 4-pot WRX brakes? Seems like from your explanation earlier that you only needed brackets in the rear and the 4-pots were a direct fit. Link to comment Share on other sites More sharing options...
N.sane Posted December 11, 2008 Share Posted December 11, 2008 Going for a set of 4-pot calipers for the fronts, LGT calipers/brackets for the rear, and DBA slotted rotors all around. The 4-pot calipers do not require mounting brackets I assume? Let me know how it goes Paul! This will be definitely on my to-do list. I drove my friend's 07 Spec.B today, the brakes are definitely a big improvement over our tiny brakes. Good luck with the swap! Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted December 11, 2008 Share Posted December 11, 2008 I was looking around in the Brakes forum, happened to run across this(problem solved!): http://www.ozliberty.com/forums/showthread.php?t=5886 Already have a walkthrough for it. Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted December 25, 2008 Share Posted December 25, 2008 these guys K got another question, are the left and right calipers identical? I got one out of two calipers in a shipping mishap, and I need to figure out which side I need. Is there any way to tell the left and right caliper apart? Link to comment Share on other sites More sharing options...
