grimlin Posted November 6, 2008 Share Posted November 6, 2008 So I picked an '09 Legacy SpecB about two months ago. Mods so far: Perrin TMIC Grimmspeed 38mm External Waste Gate Perrin Downpipe (which will be replaced with a Grimmspeed dp in 2weeks) Magnaflow Exhaust GM 3port bcs Lightweight Crank pulley Tuned Opensource by Keith (www.awdtuning.com) We put a conservative daily driving tune on it, since I'm changing a few things next week and I'm running on a patched tire (building a house next door ) but I'm still pretty happy with the numbers. Running 248whp and 288ft-lbs of tq. Mary Link to comment Share on other sites More sharing options...
Infamous1 Posted November 6, 2008 Share Posted November 6, 2008 Nice setup, no trouble with the Grimmspeed EWG UP install? Link to comment Share on other sites More sharing options...
grimlin Posted November 6, 2008 Author Share Posted November 6, 2008 well.. funny you should ask. From what I understand there isn't a bracket that fits the newer turbos.. yet. But since Keith is a Grimmspeed dealer, he had a few brackets sitting around and he used a VF bracket and modified it. Link to comment Share on other sites More sharing options...
Spec B Posted November 6, 2008 Share Posted November 6, 2008 Very nice setup! What advantage is there with EWG on a stock turbo? Link to comment Share on other sites More sharing options...
grimlin Posted November 6, 2008 Author Share Posted November 6, 2008 Very nice setup! What advantage is there with EWG on a stock turbo? I get to scared the crap out of old ladies Link to comment Share on other sites More sharing options...
grimlin Posted November 6, 2008 Author Share Posted November 6, 2008 Yeah, I know that there isn't alot of advantages with the stock turbo, but I wanted the noise and I had one sitting around in the garage just collecting dust. (it's off of my husband's car which is currently under construction for a build) Link to comment Share on other sites More sharing options...
TheShad0w Posted November 6, 2008 Share Posted November 6, 2008 Very nice setup! What advantage is there with EWG on a stock turbo? Basically - It produces a more efficient environment for any turbo. It bleeds off unnecessary hot exhausts that are no longer required to maintain target boost. It also helps regulate creep, prevents over boosting, and helps spool the turbo as fast as possible. Link to comment Share on other sites More sharing options...
Spec B Posted November 6, 2008 Share Posted November 6, 2008 Yeah, I know that there isn't alot of advantages with the stock turbo, but I wanted the noise and I had one sitting around in the garage just collecting dust. (it's off of my husband's car which is currently under construction for a build) Well...if you had one laying around, then hell yeah. You can continue to use a LGT specific DP? Link to comment Share on other sites More sharing options...
Spec B Posted November 6, 2008 Share Posted November 6, 2008 Basically - It produces a more efficient environment for any turbo. It bleeds off unnecessary hot exhausts that are no longer required to maintain target boost. It also helps regulate creep, prevents over boosting, and helps spool the turbo as fast as possible. Thanks. Link to comment Share on other sites More sharing options...
grimlin Posted November 6, 2008 Author Share Posted November 6, 2008 Well...if you had one laying around, then hell yeah. You can continue to use a LGT specific DP? Yes, the Grimmspeed one clears it just fine Link to comment Share on other sites More sharing options...
grimlin Posted November 6, 2008 Author Share Posted November 6, 2008 oh yeah, BTW, for those who don't know TheShad0w is Keith. He would actually know more about my car than I do. LOL Link to comment Share on other sites More sharing options...
Infamous1 Posted November 6, 2008 Share Posted November 6, 2008 Basically - It produces a more efficient environment for any turbo. It bleeds off unnecessary hot exhausts that are no longer required to maintain target boost. It also helps regulate creep, prevents over boosting, and helps spool the turbo as fast as possible. EWG:wub: Link to comment Share on other sites More sharing options...
TheShad0w Posted November 6, 2008 Share Posted November 6, 2008 EWG:wub: Next: TGV Deletes, 8mm. Phenolic specers, PnP EM w/Xpipe, and alcohol injection. Link to comment Share on other sites More sharing options...
Mr. Ed Posted November 6, 2008 Share Posted November 6, 2008 Next: TGV Deletes, 8mm. Phenolic specers, PnP EM w/Xpipe, and alcohol injection. front mount and green front mount and green j/k... I can't wait till YOUR car is finished Link to comment Share on other sites More sharing options...
grimlin Posted November 6, 2008 Author Share Posted November 6, 2008 sorry. No front mount and your green won't fit my car Link to comment Share on other sites More sharing options...
HansGT Posted November 6, 2008 Share Posted November 6, 2008 nice set up. numbers sound consistent with your mods. Link to comment Share on other sites More sharing options...
lordeldor Posted November 7, 2008 Share Posted November 7, 2008 So I picked an '09 Legacy SpecB about two months ago. Mods so far: Perrin Downpipe (which will be replaced with a Grimmspeed dp in 2weeks) Is the Grimmspeed dp in production? I have been watching for it for a little while. Link to comment Share on other sites More sharing options...
grimlin Posted November 7, 2008 Author Share Posted November 7, 2008 Is the Grimmspeed dp in production? I have been watching for it for a little while. No, not yet. It's still in development. My husband is a Grimmspeed dealer and we are testing out the new downpipe. I've had it in my garage for about a month, but it doesn't fit the legacy.. yet. They are fabbing a mid-pipe extension for my car so it will fit. Can't wait. Link to comment Share on other sites More sharing options...
lordeldor Posted November 7, 2008 Share Posted November 7, 2008 Ahh ok I gotcha. So Keith is your hubby then? Link to comment Share on other sites More sharing options...
grimlin Posted November 7, 2008 Author Share Posted November 7, 2008 Ahh ok I gotcha. So Keith is your hubby then? yeppers Link to comment Share on other sites More sharing options...
mickeyd2005 Posted November 8, 2008 Share Posted November 8, 2008 well.. funny you should ask. From what I understand there isn't a bracket that fits the newer turbos.. yet. But since Keith is a Grimmspeed dealer, he had a few brackets sitting around and he used a VF bracket and modified it. New turbo? Can you read the inscription? Can you tell us what is the RHFxxx number and VFyyy number? Link to comment Share on other sites More sharing options...
Infamous1 Posted November 8, 2008 Share Posted November 8, 2008 New turbo? Can you read the inscription? Can you tell us what is the RHFxxx number and VFyyy number? My guess she means the LGT style IWG vs the standard wrx/sti IWG. Link to comment Share on other sites More sharing options...
TheShad0w Posted November 8, 2008 Share Posted November 8, 2008 My guess she means the LGT style IWG vs the standard wrx/sti IWG. Correct... Link to comment Share on other sites More sharing options...
mercury3545 Posted November 8, 2008 Share Posted November 8, 2008 what waste gate are you running? Link to comment Share on other sites More sharing options...
kirbwrx Posted November 8, 2008 Share Posted November 8, 2008 man i want a grimmspeed DP, any idea how long till they come out and approx price? if its going to be too long then i might just get the harman motive one...seeing your numbers makes me want to drive up to the denton area to get a tune today...i think i talked to keith before about me coming up from abilene, are these the numbers i should expect to see? Link to comment Share on other sites More sharing options...
