yb28 Posted November 6, 2008 Share Posted November 6, 2008 Hi guys, I'm very interested in Hogzaust and i'm about to work on it probally this weekend, but there are some confusions, can anyone help me? 1.After i add the washers, there will be a flange right? if there's water, snow or salt go in from that flange, will it damage the muffers/exhaust? 2.what should i pay attension when i'm doing this? like will there be anything that's gunna dropped in and there's a gasket between those pipes right? do i have to put the gasket on after i add the washers? thankssss sooo much! Link to comment Share on other sites More sharing options...
autotech Posted November 8, 2008 Share Posted November 8, 2008 1. I wouldnt worry about stuff getting in there. More often then not it will be blowing everything out anyway. And water is in the exhaust anyway sometimes in the AM so again i wouldn't worry. 2. The only thing i would worry about would be breaking the bolts if they are corroded badly or rusted. Spray some PB blaster on there or some kind of penetrating oil on there to try and free it up a little bit. As for the gasket, i just took mine out completely, it would whistle a little bit when it was in there, so i just removed it. I had 4 washers in mine so it was pretty loud and open. Link to comment Share on other sites More sharing options...
underpowerd Posted November 9, 2008 Share Posted November 9, 2008 +1, those bolts back there near the cans can be very tough to break loose, especially with the tight quarters you'd be in w/o a lift. liquid wrench/PB definitely>wd40 (and you will need it), and don't even try it with 3/8" drive. be sure to use jackstands at minimum for safety. no real point in reinstalling gasket if a leak is the goal. you'll have openings, so yes, debris could enter, but afaik a lot of ppl have subscribed to the mod, and not any reports of trauma to the exhaust system from such. good luck with the work. Link to comment Share on other sites More sharing options...
yb28 Posted November 10, 2008 Author Share Posted November 10, 2008 thanks everyone UNDERPOWERD- i'm not too understand about "+1, those bolts back there near the cans can be very tough to break loose, especially with the tight quarters you'd be in w/o a lift. liquid wrench/PB definitely>wd40 (and you will need it), and don't even try it with 3/8" drive. " cause you explain moree? I'm 14 only but i'm sure i could do it Link to comment Share on other sites More sharing options...
yb28 Posted November 10, 2008 Author Share Posted November 10, 2008 also will is watse gas and loose low torque? Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted November 10, 2008 Share Posted November 10, 2008 No and no. Link to comment Share on other sites More sharing options...
yb28 Posted November 10, 2008 Author Share Posted November 10, 2008 it wont? amm...no offense, but how do you know? Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted November 10, 2008 Share Posted November 10, 2008 Link to comment Share on other sites More sharing options...
yb28 Posted November 10, 2008 Author Share Posted November 10, 2008 lol??? cause if i ruin the car, my mum is gunna kill me.. Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted November 10, 2008 Share Posted November 10, 2008 I'm 14 only but i'm sure i could do it Wait, you are 14 with a Legacy GT? Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted November 10, 2008 Share Posted November 10, 2008 @ Mum Goddamn Cunucks!!! Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted November 10, 2008 Share Posted November 10, 2008 It's a 2.5i big H. Link to comment Share on other sites More sharing options...
yb28 Posted November 10, 2008 Author Share Posted November 10, 2008 lol.....mine is 2.5 NA and yea, it's my mum's Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted November 10, 2008 Share Posted November 10, 2008 So you want to do a Hogzaust mod with an NA Ahh to be 14 again Link to comment Share on other sites More sharing options...
yb28 Posted November 10, 2008 Author Share Posted November 10, 2008 well is it work on NA? and yrrr...why 14 cant do it. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted November 10, 2008 Share Posted November 10, 2008 ^^ That doesn't make sense in English. Care to give it another try? Link to comment Share on other sites More sharing options...
yb28 Posted November 10, 2008 Author Share Posted November 10, 2008 huh? Link to comment Share on other sites More sharing options...
alaskajoel Posted November 10, 2008 Share Posted November 10, 2008 LGT-NY / Heights...where on earth did you find those avatars:lol: BTW, 14 year-olds can drive in Ontario? Link to comment Share on other sites More sharing options...
yb28 Posted November 10, 2008 Author Share Posted November 10, 2008 oh....no....at least 16 but i'm obsessed with cars and sounds, so....i'm about to do it but i'm trying to ask for more information b4 i do it then someone is just making fun. Link to comment Share on other sites More sharing options...
underpowerd Posted November 10, 2008 Share Posted November 10, 2008 thanks everyone UNDERPOWERD- i'm not too understand about "+1, those bolts back there near the cans can be very tough to break loose, especially with the tight quarters you'd be in w/o a lift. liquid wrench/PB definitely>wd40 (and you will need it), and don't even try it with 3/8" drive. " cause you explain moree? I'm 14 only but i'm sure i could do it yb28, in short what i'm saying is those benign looking bolts can be some of the toughest things to get off the car. please take no offense, but that you didn't understand the elementary items (penetrating oils [pb blaster, liquid wrench,], ratchet drives [3/8, 1/2"]) mentioned in my post, coupled with your age and the project you intend to tackle, is cause for some concern. in other words: in this case, it's easy to see what has to be done, but it is a lot more difficult and a bit more complex than you might imagine to actually get it done, and get it done safely. please be very cautious/ask for help from a mechanic if we can't advise you not to bother attempting this at all. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted November 10, 2008 Share Posted November 10, 2008 LGT-NY / Heights...where on earth did you find those avatars:lol: BTW, 14 year-olds can drive in Ontario? Just some trashbag that lurks this site. Link to comment Share on other sites More sharing options...
JoeFromPA Posted November 10, 2008 Share Posted November 10, 2008 I removed these 2 bolts when instlaling my sway bars for one of the cans....there was no gasket stock Re-tightened and everything seems fine. Gonna do 1 washer per bolt eventually to see what it sounds like. Joe Link to comment Share on other sites More sharing options...
CTATV Posted November 10, 2008 Share Posted November 10, 2008 been told hoggy on a NA sounds like crap, but it wont hurt anything... NY actually commented positively when he heard mine.... but a few months and I'll have my pineapple shooter 4" Greddy EvoII Link to comment Share on other sites More sharing options...
mkee87 Posted May 26, 2014 Share Posted May 26, 2014 Help, I was doing the hogzaust mod and my washers fell down the exhaust pipe... Link to comment Share on other sites More sharing options...
