LowFast Posted October 28, 2008 Share Posted October 28, 2008 Have 56k on the stock brakes and time for at the least new pads. I know that you should turn or replace the rotors (in college on our honda I went the cheap route and only did pads without any noise or other issues). What is the best for a daily driven non-track car. I would like better feel and stopping than stock, I love the looks of the big brake kit, I am a brake whore when it comes to these, but it is really not justifiable based on how we use the car. Any good package deals out there? I looked at the rotors yesterday, they look clean with very little scaring. Do I go pads. lines, fluid, and rotors, or just pads (fluid was changed about 25k ago). Do the calipers need a rebuid? Any help pointing me in the right direction would be great. Link to comment Share on other sites More sharing options...
Bolksey85 Posted October 28, 2008 Share Posted October 28, 2008 The rotors may be getting low by now so it's probably worth it to replace them. Best available for a DD is OE. Couple OE rotors with Hawk HPS pads and you're golden. If you feel you want the insurance, get SS lines, as well. Either way, you may want a flush. If the calipers are good, no need for a rebuild or replacement. Link to comment Share on other sites More sharing options...
LowFast Posted October 28, 2008 Author Share Posted October 28, 2008 Best place to pick-up stock rotors? I am sure the stealership wants $$ for them. From what I have read everyone seems to like the Hawk HPS pads. Link to comment Share on other sites More sharing options...
HansGT Posted October 28, 2008 Share Posted October 28, 2008 ^ Rotors: OEM are just fine (DBA's if you want better heat handling) Pads: Hawk HPS Fluid: Motul or Super Blue How about tires? Perhaps some new sticky ones. (you don't need lines, waste of money IMO, especially for a daily driver.) You can get everything here...dealer that also has aftermarket parts. PM Jeremy. http://www.legacygt.com/forums/showthread.php?t=98385 Link to comment Share on other sites More sharing options...
LowFast Posted October 28, 2008 Author Share Posted October 28, 2008 Running 215/45 Kumho SPTs, just put on yesterday, nice tire so far but comparble to the stock Spec-B tires. Thanks for the link. Link to comment Share on other sites More sharing options...
Gary Bechtold Posted October 28, 2008 Share Posted October 28, 2008 http://www.liteswap.com/merchant2/merchant.mvc?Screen=CTGY&Store_Code=L&Category_Code=LGTSpecial I did the OEM style rotors, Hawk HPS Pads, Prospeed GS610 fluid and SS Lines. I'm happy with the result. Link to comment Share on other sites More sharing options...
ilh Posted October 28, 2008 Share Posted October 28, 2008 I have never understood the obsession with turning or replacing rotors unnecessarily. My stock rotors measured to 0.3mm of wear out of 2.0mm. They were not scored and are working fine with new HPS pads. Not a peep has come out of them over their first 3 months. You don't know "rotors may be getting low" unless you measure. --Lee Link to comment Share on other sites More sharing options...
LowFast Posted October 28, 2008 Author Share Posted October 28, 2008 I have a micrometer to use, what is the minimal acceptable thickness before replacing? Link to comment Share on other sites More sharing options...
ilh Posted October 28, 2008 Share Posted October 28, 2008 LGT/SpecB according to vacation pix Front: 30mm down to 28mm Rear: 18mm down to 16mm Link to comment Share on other sites More sharing options...
LowFast Posted October 28, 2008 Author Share Posted October 28, 2008 ^Thanks^ Link to comment Share on other sites More sharing options...
GTTuner Posted October 28, 2008 Share Posted October 28, 2008 Hawk pads FTW. Link to comment Share on other sites More sharing options...
forayzor Posted October 30, 2008 Share Posted October 30, 2008 ^ (you don't need lines, waste of money IMO, especially for a daily driver.) You can get everything here...dealer that also has aftermarket parts. PM Jeremy. http://www.legacygt.com/forums/showthread.php?t=98385 ^true, new lines would be a waste of money, i wouldnt worry about the fluid either there shouldnt be any reason your fluid is bad and needs to be replaced. the writers at the ford dealer where i work always try selling brake flushes to people i cant stand it because its not necessary Link to comment Share on other sites More sharing options...
Max Capacity Posted October 31, 2008 Share Posted October 31, 2008 Have your OEM rotors turned and buy Bendix ceramic pads from the local auto part store. For 95% of us that's fine. I did buy Litespeed slotted front rotors but still have the bendix ceramic pads, very little dust and more then enough braking for me. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Inigo Montoya Posted November 4, 2008 Share Posted November 4, 2008 I just purchase DBA slotted rotors and Hawk HPS for just of 300 shipped for the fronts from one of the vendors in the marketplace, they should get here next week, looking forward to not having the car shake anymore. I just use oem rotors and hawk hps in the rear. Link to comment Share on other sites More sharing options...
