Whiteline RCA question.
jim1969
I'm currently on JDM Spec B Rev C Bilsteins with Pink springs. Is my car lowered enough to justify getting the Whiteline RCA kit or am in the normal range Subaru intended since I am using springs matched to the struts? I'm also running f/r sways.
I forgot how much the pinks lower on the bilsteins?
So why don't you measure? from the ground, through the center of the wheel, to the fender arch. Make sure you note the height of the centerline of the wheel as well.
The wiki says .5" but it also says (correction: "said" someone updated it with my info :)) 1 inch drop for the Swifts, and that is way off.
