Guest Posted September 28, 2008 Share Posted September 28, 2008 Question to people who installed roll center kits like the Whiteline. How much static camber do you run? Since the kits improve the camber curve, it would make sense to run somewhat less static camber than without such a kit. I am thinking about dialing in only -1 deg camber with the kit. Not enough? Link to comment Share on other sites More sharing options...
Gmachine Posted September 28, 2008 Share Posted September 28, 2008 I run -1.5 static. It would be more accurate to say the roll center kits "restore" your camber curve as a result of suspension lowering. I am currently lowered as measured from hub center to fender lip at 13 1/4 in". I see no problems running -1 for a daily driven car,see how it handles at the limit and adjust accordingly. Link to comment Share on other sites More sharing options...
jamal Posted September 28, 2008 Share Posted September 28, 2008 not enough camber for what? if you're just driving to work or whatever very little camber would be best. Track and auto-x you'd want more like -3 degrees. I'd still suggest more like -1.5 if you can get there. Link to comment Share on other sites More sharing options...
Underdog Posted September 29, 2008 Share Posted September 29, 2008 Running -1 all around. If you need a reminder on my full setup let me know, but I'm running Konis/Swifts. The Crimson Dynamo Link to comment Share on other sites More sharing options...
jamal Posted September 29, 2008 Share Posted September 29, 2008 More camber up front is going to make the car less understeery and provide more overall grip. You have more weight and a worse camber curve, and you need to compensate with more camber. Even with the RCA. Link to comment Share on other sites More sharing options...
Guest Posted September 29, 2008 Share Posted September 29, 2008 not enough camber for what? if you're just driving to work or whatever very little camber would be best. Track and auto-x you'd want more like -3 degrees. I'd still suggest more like -1.5 if you can get there. For occasional track and autox. Yeah, I'll see how far it will go on stock bolts - the car is lowered on coliovers (I don't run camber plates, although considering them). Link to comment Share on other sites More sharing options...
BrownBoy Posted September 30, 2008 Share Posted September 30, 2008 I run -1.7*. This is mainly due to fender clearance issues with the higher caster settings and lowered ride height though. Link to comment Share on other sites More sharing options...
