yergo88 Posted March 19, 2013 Share Posted March 19, 2013 I also ordered some dynamat sheets that I have to cut out myself, but did you dampen the whole door? or just what I see in the pics, ty for the tutorials!! Link to comment Share on other sites More sharing options...
mrmako Posted March 20, 2013 Author Share Posted March 20, 2013 I also ordered some dynamat sheets that I have to cut out myself, but did you dampen the whole door? or just what I see in the pics, ty for the tutorials!! The only deadening I have is what was already in the door. I should have gotten some as long as I had the door popped open. Sorry, I can't help on that. Edit: I do have some foam I put by the crossover, but that was more for mounting than deadning. Link to comment Share on other sites More sharing options...
legacyshawn Posted September 28, 2014 Share Posted September 28, 2014 Hey just wanted to post my results after todays install thanks to mrmako. Here is some of my install pics. Instead of dynamat, i used FrostKing duct insulation self adhesive foil and foam roll. One roll (12" x 1/8" x 15') was enough to fully cover the two front doors and the front door panels for only $19. Also, I ran speaker wires which was a complete PITA so i cut a little slit in the rubber hose after removing the seal on the door, used a zip to as a fishing line to pull attach to my speaker wires and pull it through. Electrical tape the hole closed and resealed and looks like stock. http://i1301.photobucket.com/albums/ag113/shabbasi/IMG_1963_zps3c110251.jpg http://i1301.photobucket.com/albums/ag113/shabbasi/IMG_1961_zpscf24799f.jpg http://i1301.photobucket.com/albums/ag113/shabbasi/IMG_1958_zpse2be95d9.jpg Link to comment Share on other sites More sharing options...
mrmako Posted September 28, 2014 Author Share Posted September 28, 2014 Nice job. Glad to see this thread is still helping people. Link to comment Share on other sites More sharing options...
hitmn Posted December 20, 2014 Share Posted December 20, 2014 Sorry but I have to ask. Are you using factory stereo for these speakers, or you have additional amplifier ? thanks Link to comment Share on other sites More sharing options...
legacyshawn Posted December 21, 2014 Share Posted December 21, 2014 I have the stock stereo wired to a equalizing digital line 6 channel line out converter (audio control LCQ-1) then wired to a precision power p900.5. It pushes about 75 watts per channel at 4 ohms then like 400 watts to the sub at 2 ohm. There would be no reason for aftermarket wiring if I was going off the headunit. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 8, 2016 Share Posted September 8, 2016 So that's the only place for the crossover right? Link to comment Share on other sites More sharing options...
mrmako Posted May 19, 2017 Author Share Posted May 19, 2017 So the job I did was adding the speakers to the existing factory head unit. It worked out just fine, and there is enough power to drive the Polks. For the crossover, the door was the most convenient. I'm sure I could have opened up under the dashboard and found a place there but the door had room and they fit. Link to comment Share on other sites More sharing options...
