monkonmonk Posted September 23, 2008 Share Posted September 23, 2008 I know that there is a kit out there to prevent the lateral movement of the sway bar made by Whiteline. I ahve been unable to locate it. Any help would be greatly appreciated. I have the common symptom of the clunk, but only when turning left. I am going to check all my bolts tonight. However, I only have a Cusco rear sway with the AVO mounts and FR and RR under arm bracing. Never even touched the front sway. Hmmm.... Thanks Monk Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted September 23, 2008 Share Posted September 23, 2008 Whiteline only makes kits for Imprezas none for Legacies that I know of. I have searched all over. Link to comment Share on other sites More sharing options...
monkonmonk Posted September 23, 2008 Author Share Posted September 23, 2008 But, it shouldn't matter right, just as long as the dia. of the sway bar is correct, right? Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted September 23, 2008 Share Posted September 23, 2008 Wait, Lateral Links are something different then what you're talking about. These are lateral links: http://i211.photobucket.com/albums/bb93/bpotts1/whitelineLATERALlinks.gif Link to comment Share on other sites More sharing options...
Underdog Posted September 23, 2008 Share Posted September 23, 2008 you're talking about the lateral locks. They are shipped with all the whiteline swaybars. If you call Turn-in Concepts, they should be able to hook you up with a part number. The last two digits in the part number represent the bar diameter. BTW, you could probably make you own with hose clamps and a piece of rubber sheet material from any hardware store. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Long Island Legacy Posted September 23, 2008 Share Posted September 23, 2008 I know that there is a kit out there to prevent the lateral movement of the sway bar made by Whiteline. I ahve been unable to locate it. Any help would be greatly appreciated. I have the common symptom of the clunk, but only when turning left. I am going to check all my bolts tonight. However, I only have a Cusco rear sway with the AVO mounts and FR and RR under arm bracing. Never even touched the front sway. Hmmm.... Thanks Monk I Think you want the AVO Rear swaybar brackets,they prevent the bar from pretty much moving around. Link to comment Share on other sites More sharing options...
monkonmonk Posted September 23, 2008 Author Share Posted September 23, 2008 Yeah, I definitely meant the lateral locks. I will be honest and say I have no idea what the lateral links are for. I have the RR AVO RR Swaybar mounting brackets to the body, are there some for the front as well??? I will look into both as well as check out Turn-In concepts. Thanks. Link to comment Share on other sites More sharing options...
Long Island Legacy Posted September 23, 2008 Share Posted September 23, 2008 Yeah, I definitely meant the lateral locks. I will be honest and say I have no idea what the lateral links are for. I have the RR AVO RR Swaybar mounting brackets to the body, are there some for the front as well??? I will look into both as well as check out Turn-In concepts. Thanks. Lateral Links are the Arms that go the Long way on the rear suspension. If you have a spec B there Aluminum. Link to comment Share on other sites More sharing options...
Underdog Posted September 24, 2008 Share Posted September 24, 2008 Click here for a link with the datasheet and part number. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Buru Posted September 29, 2008 Share Posted September 29, 2008 I thought that the later links are the two bottom bars on the rear suspension. The bar on the very bottom controls the camper and the one at the back of the car does toe. A spec B has Al trailing arms and Al upper bar (this is what the bump stops hit). Please correct me if i am wrong. M Link to comment Share on other sites More sharing options...
Underdog Posted September 29, 2008 Share Posted September 29, 2008 Buru, you are correct about lateral links. The OP asked about lateral links but really wanted to know about lateral locks which are meant to prevent the lateral displacement of swaybars. The Crimson Dynamo Link to comment Share on other sites More sharing options...
