Th3Franz Posted May 20, 2004 Share Posted May 20, 2004 [url]http://www.valvoline.com/pages/rebates/rebate_details.asp?rebateid=18[/url] Just wondering what weight of oil the GT will probably use? This is synthetic, so it would be awhile before I'd use it. Gotta break the engine in first of course! -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Th3Franz Posted May 20, 2004 Author Share Posted May 20, 2004 I think I scare people away with some of my threads... :D -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
CombatCQB Posted May 20, 2004 Share Posted May 20, 2004 Never tried valvoline, always went with Mobil1. haha, I guess that's why they're giving rebates. Anyone know if valvoline do anything better than Mobil1? But I might switch to redline with the GT. Link to comment Share on other sites More sharing options...
agctr Posted May 20, 2004 Share Posted May 20, 2004 Personally I have always used the top of the line Shell Oil, its very good, synthetic as well and would be a good match for the GT Link to comment Share on other sites More sharing options...
racerdave Posted May 20, 2004 Share Posted May 20, 2004 Synthetic can be a good thing in cold climates (right Franz?) due to better cold pour-point... flows better when cold. But other than that, if you change dino oil frequently enough, it should be fine too. Oils in general are a lot better today than in the past. Link to comment Share on other sites More sharing options...
agctr Posted May 20, 2004 Share Posted May 20, 2004 Totally agree with you dave, just depends on what you are going to be really doing with the car and where you live. I suppose its a bit like brake fluid, significant gains can be made if you change the fluid that has a higher boiling point which can = less brake fade after a few big stops. Link to comment Share on other sites More sharing options...
coolbluelb Posted May 20, 2004 Share Posted May 20, 2004 I had always heard (but never independently researched) that synthetic oil broke down at higher temperatures than non-synthetic; thus providing better protection for high temperature applications like in a forced induction engine. Any truth to this? Link to comment Share on other sites More sharing options...
agctr Posted May 20, 2004 Share Posted May 20, 2004 Im sure that F1 uses synthetic oils for their V10 mules so I would suggest that at high temps it does offer better protection. Link to comment Share on other sites More sharing options...
AMT4SWA Posted May 20, 2004 Share Posted May 20, 2004 Many of the F1 teams use a blend of Mobil 1...Mobil 1 is by far the best choice for the new Legacy. Link to comment Share on other sites More sharing options...
Drift Monkey Posted May 20, 2004 Share Posted May 20, 2004 To answer the ORIGINAL question, the weight will most likely be 4w-30 from factory. I usually use Mobil1 (readily available, cheap at Wal-Mart), but I've heard good things about Red Line/Amsoil/Royal Purple. Link to comment Share on other sites More sharing options...
CombatCQB Posted May 20, 2004 Share Posted May 20, 2004 [quote name='Th3Franz']http://www.valvoline.com/pages/rebates/rebate_details.asp?rebateid=18 Just wondering what weight of oil the GT will probably use? This is synthetic, so it would be awhile before I'd use it. Gotta break the engine in first of course![/quote] This dino vs synthetic topic still gets to me. Some people insist dino oil will help seal the rings by leaving deposits, but a lot of performance vehicles now come from the factory with synthetic. Shouldn't a good engine with tight tolerances not require this dino oil sludge to work properly? In the end, like most people say, it doesn't hurt. I still wonder thou. Link to comment Share on other sites More sharing options...
RSPDiver Posted May 20, 2004 Share Posted May 20, 2004 I was under the impression that most companies perform the primary "break-in" of the engine before shipping to the dealership. I know Mistu has done this, and that's how they can advertise first oil change at 3K miles, or what have you. Anyhoo, if the highend sports cars ('Vettes, Porsches, etc) can ship from the factory w/ full synthetic, I don't see any reason [i]not[/i] to use it straight off the bat. Link to comment Share on other sites More sharing options...
schulztt2 Posted May 20, 2004 Share Posted May 20, 2004 If you want to know about oil use (dino and syn) you should visit BOBISTHEOILGUY - [url]http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=forum;f=3[/url] , especially the used oil analysis forum. Lots of real data. Can search for Subaru. Generally turbo engines are harder on oil than non-turbo. Link to comment Share on other sites More sharing options...
Drift Monkey Posted May 20, 2004 Share Posted May 20, 2004 [quote name='CombatCQB'][quote name='Th3Franz']http://www.valvoline.com/pages/rebates/rebate_details.asp?rebateid=18 Just wondering what weight of oil the GT will probably use? This is synthetic, so it would be awhile before I'd use it. Gotta break the engine in first of course![/quote] This dino vs synthetic topic still gets to me. Some people insist dino oil will help seal the rings by leaving deposits, but a lot of performance vehicles now come from the factory with synthetic. Shouldn't a good engine with tight tolerances not require this dino oil sludge to work properly? In the end, like most people say, it doesn't hurt. I still wonder thou.[/quote] There will always be a debate on which oil and when to start using syn, but you're going to hear different things from everyone you meet. Some say first oil change then syn, others will stick to 'x' amount of milage for some reason or another. Subaru says it's ok to use after break-in, so thats likey when I'll make the swtich. :) Link to comment Share on other sites More sharing options...
agctr Posted May 21, 2004 Share Posted May 21, 2004 Is the oil that Scooby puts in so bad ? Link to comment Share on other sites More sharing options...
Drift Monkey Posted May 21, 2004 Share Posted May 21, 2004 Not for break-in. Link to comment Share on other sites More sharing options...
agctr Posted May 22, 2004 Share Posted May 22, 2004 So what do you do when they put more Oil in after the 1st 2nd and 3rd services? Empty it out and put yr stuff in ? I have been tempted to give my oil to Scooby during the service but wouldnt be sure if they would actually use it or not! Link to comment Share on other sites More sharing options...
SUBE555 Posted May 22, 2004 Share Posted May 22, 2004 If you tell them to, they SHOULD, at least most places over here will. Read MOST. A few places I've heard of are very ignorant, won't even adjust your tires to the listed specs you desire as per your request. But that's not all places. If the Aussie dealerships are similar, I'd imagine they should replace the oil at the change interval with yours, unless of course they have some sort of policy against it. Give them a call and ask. Simple as that. Link to comment Share on other sites More sharing options...
CombatCQB Posted May 22, 2004 Share Posted May 22, 2004 I'm sure you'll find some dealership that will work with you. If not, find a shop that other owners have had good experience with and get them to do it. Finding a good service shop that you can be sure will do the job right the first time. Saves a lot of headaches in the long run. The worst places I know in the US are some of those instant oil change places, had some bad experience with those. Link to comment Share on other sites More sharing options...
Drift Monkey Posted May 22, 2004 Share Posted May 22, 2004 Why would one take their vehicle to the dealership for oil changes? Link to comment Share on other sites More sharing options...
gtguy Posted May 22, 2004 Share Posted May 22, 2004 [quote name='Drift Monkey']Why would one take their vehicle to the dealership for oil changes?[/quote] Because my dealership gives me a coupon for 25 free oil changes, that's why. I only get charged $5 for those miscellaneous "disposal costs." Of course, I supply my own Mobil 1 but still...the filter and labor are free. :lol: BTW, turbos luuuuv synthetic motor oil, and I like Mobil 1 a lot. I've used it in every car I have owned since about 1987. It's fantastic stuff. Kevin Link to comment Share on other sites More sharing options...
agctr Posted May 23, 2004 Share Posted May 23, 2004 The reason why i dont trust them is, I take my car to a local dealer here in Melbourne for service, very professional. I have asked them on several occasions not to do a tyre swap as it whacks the balance out and the car just runs crap. Do u think they listen. SO, if Im taking in Oil that is around AUD30-40 bucks, Im sure its going to come home, not with me in the car but in someone elses pocket! Drift, Im not taking the car there for oil change, Scooby just change the oil during the normal service. Link to comment Share on other sites More sharing options...
SUBE555 Posted May 23, 2004 Share Posted May 23, 2004 Well, I guess there is one way to find out if they do it. When you go in though, have them write down on the service ticket (at least that's what they do over here) what you exactly want done, and list no tire rotation, etc. Good luck! Link to comment Share on other sites More sharing options...
Drift Monkey Posted May 24, 2004 Share Posted May 24, 2004 [quote name='gtguy'][quote name='Drift Monkey']Why would one take their vehicle to the dealership for oil changes?[/quote] Because my dealership gives me a coupon for 25 free oil changes, that's why. I only get charged $5 for those miscellaneous "disposal costs." Of course, I supply my own Mobil 1 but still...the filter and labor are free. :lol: BTW, turbos luuuuv synthetic motor oil, and I like Mobil 1 a lot. I've used it in every car I have owned since about 1987. It's fantastic stuff. Kevin[/quote] Can't argue with free I suppose! :) Link to comment Share on other sites More sharing options...
agctr Posted May 25, 2004 Share Posted May 25, 2004 I'll let you know how I go in the next month Sube as its due for another service. Thanks for the luck, I may need it! Link to comment Share on other sites More sharing options...
