kirbwrx Posted July 11, 2009 Share Posted July 11, 2009 why would you want to run different springs in the front and rear? wouldnt the spring rates be different? Link to comment Share on other sites More sharing options...
iON Performance Posted July 11, 2009 Share Posted July 11, 2009 kirbwrx - the springs are our own designation which means different spring rates, lengths etc. Each of our spring options are engineered for each engine/chassis/tranny combination to provide a specific handling characteristic. Link to comment Share on other sites More sharing options...
peteyjr Posted July 11, 2009 Share Posted July 11, 2009 Good to have options. ION has done their homework. Jack is excellent at helping you chose the proper springs Link to comment Share on other sites More sharing options...
BradyCat Posted July 11, 2009 Share Posted July 11, 2009 iONS it is for me too! Ordered mine the other day, iON Performance's reputation on this forum is top notch, and as you can see, they are always here to chime in on questions etc not dissappearing for weeks like some vendors do after the sale! Can't wait to get them on...... will post pics ASAP (sport specB fronts/HD rears) Thanks Rushin for your input 2013 Ford Taurus SHO 2009 Spec.B SWP Stg 2+ Airboy tuned 2010 Toyota Sequoia Platinum 5.7 Link to comment Share on other sites More sharing options...
BradyCat Posted August 28, 2009 Share Posted August 28, 2009 Here's a quick pic as promised......... Ride height settled at a 7/8" drop front, and with the HD rears, a 1/8" hike up in the back here's a little review after about a month: I'm absolutely thrilled with these springs, especially how they ride. Not too harsh, but very sporty. When going over rough patches of road, bumps or small potholes, there is no chattering within the suspension itself; it seems like it rides quieter than stock. Not as in road noise from the tires, but I mean there are no annoying sounds arising from the new springs, just what you expect from a nice sports sedan. The front drop is perfect, but I wish the back sat just a touch lower (the HD rears actually raised the rear up by 1/8"). One other small gripe is that the wheels seem to sit offset from the center of the wheel wells, like the new springs significantly altered how the body sits on the chassis? Install was a snap too. 2013 Ford Taurus SHO 2009 Spec.B SWP Stg 2+ Airboy tuned 2010 Toyota Sequoia Platinum 5.7 Link to comment Share on other sites More sharing options...
iON Performance Posted August 28, 2009 Share Posted August 28, 2009 BradyCat - great to see you've got them on and using them now. For the type of roads you're on the combination that you're using is best for function. The chassis itself is now level, when the car was stock, the rear of your car actually sits slightly lower. Are you using the factory tire size? Link to comment Share on other sites More sharing options...
fonts Posted August 29, 2009 Share Posted August 29, 2009 Damn. Looks sharp and like the reviews. Now I kinda pissed that I didn't go with the iON springs ...... especially from a fellow Canuck. Link to comment Share on other sites More sharing options...
SBT Posted August 29, 2009 Share Posted August 29, 2009 ^ you can't go wrong with Jack's ION products. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
BradyCat Posted September 2, 2009 Share Posted September 2, 2009 BradyCat - great to see you've got them on and using them now. For the type of roads you're on the combination that you're using is best for function. The chassis itself is now level, when the car was stock, the rear of your car actually sits slightly lower. Are you using the factory tire size? I would've PM'd you, but you can't PM pics....Yes, I'm running the factory tire size, albeit on a 1/2" wider rim. I think maybe the reason for the 1/8" lift in the rear is due to the fact that the HD springs couldn't quite sit flat on the bottom seat because of the little raised notch on it. Maybe I should've ground that little thing off? I just left it there and the spring sort of sits on top of the notch a little bit. The HD springs are noticeably thicker than the stockers, so I wasn't sure what to do there..... 2013 Ford Taurus SHO 2009 Spec.B SWP Stg 2+ Airboy tuned 2010 Toyota Sequoia Platinum 5.7 Link to comment Share on other sites More sharing options...
iON Performance Posted September 2, 2009 Share Posted September 2, 2009 BradyCat - Which orientation did you install the coils in the back? Flat side up or down? If you're running factory sized tires on a wider wheel, you're essentially reducing your exposed sidewall, hence making it look "thinner" (streching the tire) and as such increasing the wheel gap. Link to comment Share on other sites More sharing options...
BradyCat Posted September 2, 2009 Share Posted September 2, 2009 Flat side up (opposite to the second picture above). My measurements were taken from the ground to the middle of the fender, not by the wheel gap, and using the same rims/tires before and after spring install. It's not a big deal, I like the front rake it gives, but I might reinstall them someday after grinding down/off that little stopper on the lower spring seat and see if it's better.... 2013 Ford Taurus SHO 2009 Spec.B SWP Stg 2+ Airboy tuned 2010 Toyota Sequoia Platinum 5.7 Link to comment Share on other sites More sharing options...
iON Performance Posted September 3, 2009 Share Posted September 3, 2009 BradyCat - flat side up is the right orientation. Odd that you're the only person who's ran into an issue with the lower rear perch. Have you measured your actual chassis height? It should be basically even front to back. (maybe 2-3mm difference tops). Link to comment Share on other sites More sharing options...
thebootyhouse Posted September 3, 2009 Share Posted September 3, 2009 so where would I get pinks for legacy? http://www.rallitek.com/jdmstispspse.html Link to comment Share on other sites More sharing options...
