Long Island Legacy Posted September 12, 2008 Share Posted September 12, 2008 Carbotech AX6 Front pads Formally the Panther Plus. I ran these on stock rotors since Late March. I Correctly bedded them in and they were great up until the pads wore down and started to grove my rotors. The pr0oblem i had was that the pads are riveted to the rotors which makes for a bad combination when you get low on pad, plus no wear indicators as you can see from the pad on the right became so worn down for some reason that all that was left was the backing plate. this totaly destroyed my rotor. I think the pads were to agressive for OEM rotors and the extra heat they made would be to great as I have had the front rotors glowing from a spirited driving session. http://img.photobucket.com/albums/v695/creamfan/Legacy015.jpg http://img.photobucket.com/albums/v695/creamfan/Legacy014.jpg http://img.photobucket.com/albums/v695/creamfan/Legacy013.jpg http://img.photobucket.com/albums/v695/creamfan/Legacy009.jpg Brass Knuckles :lol: http://img.photobucket.com/albums/v695/creamfan/Legacy008.jpg Link to comment Share on other sites More sharing options...
Infamous1 Posted September 12, 2008 Share Posted September 12, 2008 You should of easily heard, felt or seen that Link to comment Share on other sites More sharing options...
Bulletproof4age Posted September 12, 2008 Share Posted September 12, 2008 How do you go through pads in 5 months? How many track events? Link to comment Share on other sites More sharing options...
Th3Franz Posted September 12, 2008 Share Posted September 12, 2008 How do you go through pads in 5 months? How many track events? track pad + not getting to the appropriate temperature range on a daily basis = really fast pad wear and rotor eatage -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
EquinnoxX Posted September 12, 2008 Share Posted September 12, 2008 Ouch, they looked bad when i saw them but man i didn't know they were that bad!! Guess that means its time for some more upgrades Link to comment Share on other sites More sharing options...
PhilT Posted September 12, 2008 Share Posted September 12, 2008 That's crazy, a daily walk around the car could have easily avoided that. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Long Island Legacy Posted September 12, 2008 Author Share Posted September 12, 2008 I knew about them being low but the $$ was tight. Anyway upgraded to Brakeswap Slotted Front Rotors and Hawk HPS all around. Link to comment Share on other sites More sharing options...
robinlsb Posted September 12, 2008 Share Posted September 12, 2008 Ouch, they looked bad when i saw them but man i didn't know they were that bad!! Guess that means its time for some more upgrades That kind of rotor wear is caused by overheating the rotors. You have, in effect, melted material off the rotors! And cast iron melts at about 1100 degrees! Time for better rotors or BBKs and maybe even ducting:eek: "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted September 12, 2008 Share Posted September 12, 2008 Not doing your research.... FTL! Link to comment Share on other sites More sharing options...
Long Island Legacy Posted September 12, 2008 Author Share Posted September 12, 2008 That kind of rotor wear is caused by overheating the rotors. You have, in effect, melted material off the rotors! And cast iron melts at about 1100 degrees! Time for better rotors or BBKs and maybe even ducting:eek: They were red hot a few times. Link to comment Share on other sites More sharing options...
jamal Posted September 14, 2008 Share Posted September 14, 2008 That kind of rotor wear is caused by overheating the rotors. You have, in effect, melted material off the rotors! And cast iron melts at about 1100 degrees! Time for better rotors or BBKs and maybe even ducting:eek: Yeah sure that's why all the GT2 lemans rotors turn into a goopy mess at +1600f. That kind of rotor wear is caused by wearing the pads down to the backing plates and then continuing to drive on them. It doesn't matter if you have race pads or cheap crap from pep-boys. Link to comment Share on other sites More sharing options...
RobY Posted September 14, 2008 Share Posted September 14, 2008 cast iron melts at about 1100 degrees! Only if you are european... If you are american it melts at about 2200 degrees Link to comment Share on other sites More sharing options...
robinlsb Posted September 14, 2008 Share Posted September 14, 2008 Yeah sure that's why all the GT2 lemans rotors turn into a goopy mess at +1600f. That kind of rotor wear is caused by wearing the pads down to the backing plates and then continuing to drive on them. It doesn't matter if you have race pads or cheap crap from pep-boys. Well, that would be true, if you could buy composite ceramic rotors or carbon rotors at Pep boys. But since you can't buy them at Pep boys, and GT2 cars use composite ceramic rotors, are you sure that you know what you are talking about? "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
PhilT Posted September 14, 2008 Share Posted September 14, 2008 That is completely metal on metal wear, no matter how cold the brakes are that's what you get when you have no friction material left. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Infamous1 Posted September 14, 2008 Share Posted September 14, 2008 Only if you are european... If you are american it melts at about 2200 degrees Haha yep, or these damn exhaust manifolds would of melted long ago. Link to comment Share on other sites More sharing options...
fweasel Posted September 14, 2008 Share Posted September 14, 2008 Only if you are european... If you are american it melts at about 2200 degrees :lol: This episode had nothing to do with "track" pads. User error. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
robinlsb Posted September 14, 2008 Share Posted September 14, 2008 That is completely metal on metal wear, no matter how cold the brakes are that's what you get when you have no friction material left. All I can say is that I have scored brakes using track pads on regular brakes, albeit not as bad as those shown is the pic. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
sirsimon Posted September 14, 2008 Share Posted September 14, 2008 Yeah, I considered buying Ferodo DS3500 pads when my 2500s wore out, as I've heard that they really require little time to get usably warm (just a stop or two), but they will wear out my (expensive) Alcon rotors like their is no tomorrow. Link to comment Share on other sites More sharing options...
jamal Posted September 14, 2008 Share Posted September 14, 2008 Well, that would be true, if you could buy composite ceramic rotors or carbon rotors at Pep boys. But since you can't buy them at Pep boys, and GT2 cars use composite ceramic rotors, are you sure that you know what you are talking about? Plenty of them use iron. prototypes and gt1 cars generally have carbon brakes though. I think my point was something else. Link to comment Share on other sites More sharing options...
