d1a9j Posted September 11, 2008 Share Posted September 11, 2008 First off sorry if I didn't post this in the right section. Secondly, sorry if these questions were asked/answered before (I searched and couldn't find anything useful). Just wondering what that box thing is on my gf's legacy ??? I was looking to remove the silencer on the after maf hose and replace it with a smoother flowing hose. I noticed there are 2 lines (one on each side of the box) what are they for ? Also Is there a way to bypass that box and just have a hose going right into the tb ??? Thanks for any and all help, - Dave http://img.photobucket.com/albums/v246/D1A5J/suby012.jpg http://img.photobucket.com/albums/v246/D1A5J/suby013.jpg Link to comment Share on other sites More sharing options...
d1a9j Posted September 12, 2008 Author Share Posted September 12, 2008 23 views and no help ?!?!?! some1 has to know !!! Link to comment Share on other sites More sharing options...
SuperCleanLGT Posted September 12, 2008 Share Posted September 12, 2008 Trace them to their origen and put breather filters on the supply nipples. Link to comment Share on other sites More sharing options...
d1a9j Posted September 13, 2008 Author Share Posted September 13, 2008 ok, now does any1 know what the box does ??? Link to comment Share on other sites More sharing options...
d1a9j Posted October 20, 2008 Author Share Posted October 20, 2008 ... i guess not ?!?!?! Link to comment Share on other sites More sharing options...
addison Posted October 20, 2008 Share Posted October 20, 2008 ok, now does any1 know what the box does ??? adds restriction. Link to comment Share on other sites More sharing options...
Osei Posted October 21, 2008 Share Posted October 21, 2008 go to naturally aspirated forum and search under intake. You'll find all the answers you are looking for. O. Link to comment Share on other sites More sharing options...
vr4Legacy Posted October 21, 2008 Share Posted October 21, 2008 that box creates an air plenum. Basically it holds a large quantity of air so that upon sudden acceleration from low rpm and low air intake airflow, you will have a ready quantity available. If you install an full aftermarket intake (not short ram), the box comes out, but if you accelerate quickly from a start (or on a steep hill with a manual) you need to rev the engine a little to create enough airflow otherwise the engine will bog down. I know from experience because I put on in my '98 Impreza L If you want to simply create a "ricer" sound you can remove the silencers (that thing to the left of the plenum in the first pic, coming off the intake) that are sticking off the pipe and retain the plenum. Link to comment Share on other sites More sharing options...
d1a9j Posted October 21, 2008 Author Share Posted October 21, 2008 that box creates an air plenum. Basically it holds a large quantity of air so that upon sudden acceleration from low rpm and low air intake airflow, you will have a ready quantity available. If you install an full aftermarket intake (not short ram), the box comes out, but if you accelerate quickly from a start (or on a steep hill with a manual) you need to rev the engine a little to create enough airflow otherwise the engine will bog down. I know from experience because I put on in my '98 Impreza L If you want to simply create a "ricer" sound you can remove the silencers (that thing to the left of the plenum in the first pic, coming off the intake) that are sticking off the pipe and retain the plenum. what are you using to plug that hole once u remove the silencer ??? Link to comment Share on other sites More sharing options...
vr4Legacy Posted October 21, 2008 Share Posted October 21, 2008 I have never done this, I saw a lot of write ups on Nasioc.com about 5 years ago... as mentioned search the N/A thread on here and I'm sure you can find some info. My guess would be to use some oversized tubing and a couple of hose clamps, but that wouldn't look the best. My suggestion is to get a "short ram" intake, such as an SPT one. You can find them cheap on e-bay, which will effectively do the same thing with a cheap filter. (I'm sure you won't get as good a flow, but you will achieve better flow than stock) Link to comment Share on other sites More sharing options...
