Robscort Posted September 9, 2008 Share Posted September 9, 2008 Hi everyone, I apologize if this question has already been asked. I searched around but didn't find a conclusive answer. I am considering the purchase of a 2009 OBXT, but what I really want is a Legacy 2.5 GT wagon, which Subaru doesn't offer anymore. So, I was wondering what's different between the two cars. From digging around, it appears the OBGT uses a spacer between the body and subframe, which also results in longer(?) struts to compensate for the increased body height, and finally, I believe the OBXT has a slower steering rack and smaller brakes. Are those all the differences? I don't need the increased ride height of the OBXT, so I would be willing to pull the spacers and install coilovers on day one if necessary. I just want to make sure it's that easy. Thanks, Robert PS I realize Megan makes a set of OBXT specific coilovers which don't require the removal of the body spacers, but I would prefer using coilovers from Cusco or Tein if they're available... Link to comment Share on other sites More sharing options...
Beanboy Posted September 9, 2008 Share Posted September 9, 2008 Rear camber will be out of whack. Believe there are adjustable camber arms around, or at least talked about somewhere. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Robscort Posted September 11, 2008 Author Share Posted September 11, 2008 Thanks beanboy... Would the camber be altered more than it would be on any car that's been lowered, or is there an inherent design characteristic of the suspension that exacerbates the negative camber issue? Also, what's involved in removing the body spacers? Pretty straightforward, or is it a pain? Do brake lines need to be rerouted, etc? Finally, how tall are the spacers? How much is gained by removing them alone? Thanks again, Robert Link to comment Share on other sites More sharing options...
BlackHole Posted September 11, 2008 Share Posted September 11, 2008 Per unclemat some the suspension arms are different between LGT and OBXT. Search - there is a good summary of differences in one of the forums. Kyle "BlackHole" Link to comment Share on other sites More sharing options...
westy66 Posted September 14, 2008 Share Posted September 14, 2008 interesting question. has anyone previously bought a OBXT and slammed it? i guess that would totally defeat the purpose, but.... you never know. Link to comment Share on other sites More sharing options...
Beanboy Posted September 14, 2008 Share Posted September 14, 2008 Suspension design. You ever see a Honda Ridgeline loaded down? Slam an OUtback and that's what you would get to some degree until you replaced the arms/got adjustable ones. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
