DukeTrout Posted July 31, 2008 Share Posted July 31, 2008 The spec b max shifting speeds are: 1st - 33 mph 2nd - 51 mph 3rd - 69 mph 4th - 90 mph 5th - 125mph Seems you would definitely need to hit 5th for the 1/4 mile in this car unless you really mess up. These don't seem to be "short ass" gears either as mentioned above. The 5spd max shift points are: 1st - 32 mph 2nd - 54 mph 3rd - 80 mph 4th - not listed These may be the calculated speeds, but according to the nav signal speed in the real world, fuel cut-off at 6750 rpm on the 07 spec.B in 2nd is 59 mph. I'll have to check the same for 4th some time. Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
Throttlejockey Posted July 31, 2008 Share Posted July 31, 2008 Well he does have an ap, did the ap raise your redline at all? It definitely raises the rev-limiter. IIRC it's about 500rpm. Link to comment Share on other sites More sharing options...
rtbrjason Posted August 1, 2008 Share Posted August 1, 2008 Well I was able to get a solid couple tests in today of max speeds in the first 3 gears on my 08 spec b. They are as UnXpectedError state above. 1st - 34 mph 2nd - 56 mph 3rd - 80 mph I didn't and won't have much chance to test 4th until I get to a strip if ever. It's nice to know the data around this in the manual is completely meaningless. Link to comment Share on other sites More sharing options...
VTGT Posted August 1, 2008 Share Posted August 1, 2008 why does everyone worry about this? Like the AP is accurate. If you want real times go datalog then complain ahaha Link to comment Share on other sites More sharing options...
05GT Guru Posted August 1, 2008 Share Posted August 1, 2008 If you want real times go to the track Link to comment Share on other sites More sharing options...
VTGT Posted August 3, 2008 Share Posted August 3, 2008 ^That would be even better Link to comment Share on other sites More sharing options...
Richard B. Posted August 3, 2008 Share Posted August 3, 2008 why does everyone worry about this? Like the AP is accurate. If you want real times go datalog then complain ahaha it theoretically should be accurate to 60. it is a time and not a distance. assuming it reads from the speedo and that in it self is accurate i fail to see where the ap wouldn't be good. distance? yeah i can understand. Link to comment Share on other sites More sharing options...
