Long Island Legacy Posted July 25, 2008 Share Posted July 25, 2008 Okay so far my perrin 3"downpipe i installed on my car has not been very friendly with mating up to the stock exhaust very well. For one the donut gasket trick to flip it around was not successfully as the gasket was stuck on the oem downpipe. Then i got a vibrant 3" exhaust gasket and still i have leaks. The problem is the flange on the downpipe does not seal completely on the stock midpipe flange. Does anyone have any suggestions for what i should do. Right now the exhaust leaks during deceleration because of the engine moving back and fourth. Link to comment Share on other sites More sharing options...
camber Posted July 25, 2008 Share Posted July 25, 2008 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=018&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=280210808193&rd=1 WBR makes ones as well. Link to comment Share on other sites More sharing options...
NewLegGT67 Posted July 25, 2008 Share Posted July 25, 2008 not been very friendly with mating up to the stock exhaust very well. Welcome to Perrinville. I'm probably the only person that has Wu-Tang Clan and Paul McCartney on their mp3. Link to comment Share on other sites More sharing options...
Long Island Legacy Posted July 25, 2008 Author Share Posted July 25, 2008 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=018&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=280210808193&rd=1 WBR makes ones as well. Is that the size of the stock mid pipe inlet 2.5? I think that would work in my situation cause it simulates a donut gasket for the stock mid pipe. Link to comment Share on other sites More sharing options...
vet Posted July 25, 2008 Share Posted July 25, 2008 I've got a Perrin DP; been using 2 gaskets with no leaks. Link to comment Share on other sites More sharing options...
Long Island Legacy Posted July 26, 2008 Author Share Posted July 26, 2008 I've got a Perrin DP; been using 2 gaskets with no leaks. You have the 3 inch catless one? and you used two gaskets and it sealed 100% with the stocker? mine seems to leak at the top of the flange for some reason. Link to comment Share on other sites More sharing options...
Long Island Legacy Posted July 26, 2008 Author Share Posted July 26, 2008 bump Link to comment Share on other sites More sharing options...
Soda Popinski Posted July 26, 2008 Share Posted July 26, 2008 I just came here to post a similar topic: I just installed an invidia catted high flow downpipe to a cobb CBE. On acceleration between 1500 rmps to 2000 rpms, and from deceleration from 4000 rmps down to 1500... it sounds like a rattle or almost as if there is a washer floating around in the exhaust. I didn't notice this until I was driving through a store parking lot, and could hear the echo off the buildings and cars. The invidia down doesn't use the donut gasket. The cobb CBE is countersunk to accept it, but I didn't use it. the invidia downpipe came with a regular gasket... so I just used this. Is this the same problem you are having? Link to comment Share on other sites More sharing options...
Long Island Legacy Posted July 26, 2008 Author Share Posted July 26, 2008 Yea except i have the stock exhaust. Does the invidia have a flat flange? My perrin dP has a 3 inch flat flange. Link to comment Share on other sites More sharing options...
Soda Popinski Posted July 26, 2008 Share Posted July 26, 2008 The invidia has a flat flange, but a divorced wastegate. That center divider is causing the rattle in the turbo housing and echoing down. Was wondering if your downpile also had a divorced or split wastegate? Link to comment Share on other sites More sharing options...
Long Island Legacy Posted July 26, 2008 Author Share Posted July 26, 2008 it divorced but i have a perrin so they got that part right at least. Link to comment Share on other sites More sharing options...
vet Posted July 26, 2008 Share Posted July 26, 2008 You have the 3 inch catless one? and you used two gaskets and it sealed 100% with the stocker? mine seems to leak at the top of the flange for some reason. Yeah, I bought the perrin dp used and it came with two gaskets so I just bolted it up to my stock resonator/y-pipe and haven't had any problems. Link to comment Share on other sites More sharing options...
sschmelcke Posted July 27, 2008 Share Posted July 27, 2008 i have the invidia and just had a muffler shop weld a new flange on my stock pipe so it would mate up better. i was also getting a leak from the top of the stock flange. Link to comment Share on other sites More sharing options...
05gtlimited300 Posted July 30, 2008 Share Posted July 30, 2008 use hi-temp silicone around the flanges Link to comment Share on other sites More sharing options...
gianspi Posted August 1, 2008 Share Posted August 1, 2008 http://www.permatex.com/images/DisplayImage.asp?210%7C/images/ProductPhotos/81878.jpg http://www.permatex.com/products/Automotive/automotive_gasketing/gasket_makers/auto_Permatex_Ultra_Copper_Maximum_Temperature_RTV_Silicone_Gasket_Maker.htm enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
