Turkeylord Posted July 24, 2008 Share Posted July 24, 2008 Hey guys, found a couple of threads with similar issues, but wanted to post anyway as mine's a little different.. Vehicle is a '00 LGT 5MT with 105k and I only get the clunk under pretty specific conditions.. It only happens on low-speed tight cornering (parking), and only just after putting on some highway miles. IE - I take it out and put on 60+ highway miles, then it will clunk clunk clunk while turning into parking spots, etc. When I go to drive it again the next day - the problem is gone! Sounds like it's coming from the front of the car, but I'm not sure where exactly.. Center diff? Front diff? Axles? Wheel bearings? Ugh.. Should I try the tranny flush/fill that has worked for some? Any other suggestions? Thanks guys, Jordan Link to comment Share on other sites More sharing options...
KnifeyMcShanker Posted July 25, 2008 Share Posted July 25, 2008 Definitely sounds like a diff thing. Sure it isn't the rear? That's where I'd expect it to come from during tight cornering... Link to comment Share on other sites More sharing options...
jonklein611 Posted July 25, 2008 Share Posted July 25, 2008 My CV joints do this when i corner super tight at slow speeds Link to comment Share on other sites More sharing options...
icrackedcorn Posted July 29, 2008 Share Posted July 29, 2008 visual inspection of the CVs would rule that out (or in) immediately obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
Boost-Drive-Love Posted July 31, 2008 Share Posted July 31, 2008 Look under the car at your CV boots. They don't need to be ripped in order to be no good, but they probably are by now and have lost their lubricant. Stop the vehicle in an open space. Put it in gear, turn all the way to the direction you hear the sound, let the car idle itself, then accelerate just for a second while turning. If the sound is a constant clicking - the CV axle on the opposite side of the direction you turned is no good. If you turned left and heard it, the RH CV is bad. If you turn right and hear it, the LH CV is bad. The longer you let it go, the louder the clicking will become and more likely the joint is to completely fail - don't let the issue slide, replace it asap. Link to comment Share on other sites More sharing options...
