black318i Posted July 17, 2008 Share Posted July 17, 2008 Anybody know what the camber will be with a 1" drop? Link to comment Share on other sites More sharing options...
Underdog Posted July 17, 2008 Share Posted July 17, 2008 Search for my thread "In search of high-speed stability"... In that thread I have some alignment specs from after I installed my Swifts, which were just >1" drop. The Crimson Dynamo Link to comment Share on other sites More sharing options...
black318i Posted July 17, 2008 Author Share Posted July 17, 2008 Great thanks Link to comment Share on other sites More sharing options...
Underdog Posted July 17, 2008 Share Posted July 17, 2008 http://legacygt.com/forums/showthread.php?t=60122 There the thread. Specs in post #40 show after dropping the car and getting a crappy alignment. I'm looking at the before spec on the alignment sheet that those number came from and he didn't even touch the camber adjustment... so, you could expect somewhere in the range of -1 -> -1.5 degrees all around, probably a bit more biased to the rear since it's not adjustable without aftermarket lateral links. Since you are talking about 1" drop which is less than mine the camber change might not be as "extreme". The Crimson Dynamo Link to comment Share on other sites More sharing options...
