SuBK Posted July 9, 2008 Share Posted July 9, 2008 So i did some searching and was only able to find info on the Legacy STi grill for 08+. Does anyone know where to find this one in this picture because it is the exact grill but on an 05-07. Also I know this is a JDM Legacy so will this grill still fit USDM? Or did this guy just fabricate the 08 to make it work.. any input on this would be awesome, I need one! http://i37.photobucket.com/albums/e71/bennycent50/L-STi.jpg Link to comment Share on other sites More sharing options...
ShadowImg Posted July 9, 2008 Share Posted July 9, 2008 You'd need to do a JDM bumper swap to go with it to make it fit, I'd imagine. There's pretty much no chance of it fitting a US without further changes. Link to comment Share on other sites More sharing options...
SuBK Posted July 9, 2008 Author Share Posted July 9, 2008 so if I were to do a 05 JDM bumper swap, which I can easily do a guy near me is wanting to trade for his JDM bumper, then the 08 JDM grill should fit? cuz according to this picture it looks like an 05 JDM bumper with an 08 JDM grill, correct me if I am wrong? Link to comment Share on other sites More sharing options...
ShadowImg Posted July 9, 2008 Share Posted July 9, 2008 If you think you can 'easily' swap an 05 JDM bumper to an 08 LGT, then you can probably make that grill fit too. Just realize, these are not drop in replacements, and will require cutting/fabricating to swap the bumper. You may want to consider an RBS or Rallitek 08 grill instead, which are made for the USDM 08. Link to comment Share on other sites More sharing options...
SuBK Posted July 9, 2008 Author Share Posted July 9, 2008 No.. I have an 05 LGT and can get an 05 JDM bumper, but the grill is for an 08 it looks like, sorry for the confusion.... im wanting to put this 08 grill on an 05 LGT... exactly how the picture is, that car is an 05 but the grill is 08 Link to comment Share on other sites More sharing options...
05gtlimited300 Posted July 9, 2008 Share Posted July 9, 2008 the JDM Spec B bumper requires a bigger grille much like the 08s now so you should be fine and be able to aquire the look you desire Link to comment Share on other sites More sharing options...
Hokiebird Posted July 9, 2008 Share Posted July 9, 2008 Why don't you PM Mr Luv and ask him? It's his car. Link to comment Share on other sites More sharing options...
SuBK Posted July 9, 2008 Author Share Posted July 9, 2008 ^^ thanks, will do Link to comment Share on other sites More sharing options...
mr_luv Posted July 9, 2008 Share Posted July 9, 2008 Thats the passed around grill, the tabs that would hold it to the bumper were cut and the wholes dont line up other then that it drops in its on you to secure it to the car. Mr.350 Link to comment Share on other sites More sharing options...
SuBK Posted July 10, 2008 Author Share Posted July 10, 2008 Thats the passed around grill, the tabs that would hold it to the bumper were cut and the wholes dont line up other then that it drops in its on you to secure it to the car. is it an 08 grill though? and do you know if it would fit a USDM bumper, and by fit i mean just fit in the area with no gaps, i dont care about holes and tabs lining up I can make that work somehow just as long as it sits flush between the bumper and hood with no gaps Link to comment Share on other sites More sharing options...
mr_luv Posted July 10, 2008 Share Posted July 10, 2008 It will not fit the USDM 05-07 bumpers or 08 with out some major modifications. is it an 08 grill though? and do you know if it would fit a USDM bumper, and by fit i mean just fit in the area with no gaps, i dont care about holes and tabs lining up I can make that work somehow just as long as it sits flush between the bumper and hood with no gaps Mr.350 Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted July 10, 2008 Share Posted July 10, 2008 I would love to have a grill like that. I really wish the vendors would come up with a grill like that, instead of the basic boring/blah mesh grill that takes no ingenuity or imagination to make. Link to comment Share on other sites More sharing options...
Underdog Posted August 1, 2008 Share Posted August 1, 2008 Mr_Luv, I've talked with Japanparts about picking up the JDM Spec.B Bumper Swap (Rev A-C) and STi Grille. He indicated pretty much what you have said, that it requires modifications. Questions: 1) The tabs on the bottom of the grille had to be cut since they didn't line up... How are you securing the bottom of the grille, if at all? 2) Did you have to slot the bolt/pop-it holes on the top of the grille as well? 3) Any pics of the car with the hood closed? Thanks! -Rick The Crimson Dynamo Link to comment Share on other sites More sharing options...
DiscoWagon Posted August 1, 2008 Share Posted August 1, 2008 You may want to consider an RBS or Rallitek 08 grill instead, which are made for the USDM 08. Rallitek Grill for 08? Where? Link to comment Share on other sites More sharing options...
Kyuubi9t Posted August 4, 2008 Share Posted August 4, 2008 yea, where? Link to comment Share on other sites More sharing options...
subaruski Posted December 4, 2008 Share Posted December 4, 2008 bump for info on this... Link to comment Share on other sites More sharing options...
tealdub Posted December 16, 2008 Share Posted December 16, 2008 It will not fit the USDM 05-07 bumpers or 08 with out some major modifications. Check www.subaru.co.uk under Legacy saloon. You can see the bumper is almost identical to the USDM 08+. I would think you could bolt it onto this. Link to comment Share on other sites More sharing options...
Japanparts Posted December 18, 2008 Share Posted December 18, 2008 Check www.subaru.co.uk under Legacy saloon. You can see the bumper is almost identical to the USDM 08+. I would think you could bolt it onto this. UK gets almost identical version to the JDM model; they don't require "Federal" bumpers... GW Japanparts.com Link to comment Share on other sites More sharing options...
mr_luv Posted December 20, 2008 Share Posted December 20, 2008 Almost is close but no cigar, I know 1st had it wont fit with out the likes of some sort of cutting. Mr.350 Link to comment Share on other sites More sharing options...
Japanparts Posted December 20, 2008 Share Posted December 20, 2008 Almost is close but no cigar, I know 1st had it wont fit with out the likes of some sort of cutting. Both the JDM + UK ( front ) Bumper versions will require cutting your bumper reinforcement if you are fitting these bumpers to a USA model as the foam "energy absorber" in the Federal model is physically larger, OR fitting the JDM backbeam + energy absorber saves the cutting As for interchangeability between the JDM + UK models Front bumpers will depend on the year + model; but I can't see Subaru making these different ( and will be happy to compare Part numbers to confirm that ) GW Link to comment Share on other sites More sharing options...
PSZCZ.lgt Posted December 22, 2008 Share Posted December 22, 2008 what kind of lip is that?? Link to comment Share on other sites More sharing options...
