Vsick Posted June 27, 2008 Share Posted June 27, 2008 Curious.....but I was only able to get an older version of ecuexplorer to work with my APV2 cable using the APV2DONGLE.EXE drivers. Are you guys using any other programs with the apv2 usb cable? only for datalogging purposes Link to comment Share on other sites More sharing options...
dbrunone Posted June 27, 2008 Share Posted June 27, 2008 im looking for something that will work with my APv2 CAN cable...ecuExplorer is ok, but super super buggy Link to comment Share on other sites More sharing options...
Infamous1 Posted June 27, 2008 Share Posted June 27, 2008 Cobb's hacked version of ECUExplorer is the only program that will work with the APv2 cable. Link to comment Share on other sites More sharing options...
Vsick Posted June 28, 2008 Author Share Posted June 28, 2008 I guess my next question is....is ecuexplorer sufficient? If yes, what parameters should I be logging so I can post here to get feedback? Link to comment Share on other sites More sharing options...
iahtnoob Posted June 28, 2008 Share Posted June 28, 2008 how do you get to that cobb hacked version?? Link to comment Share on other sites More sharing options...
Vsick Posted June 28, 2008 Author Share Posted June 28, 2008 how do you get to that cobb hacked version?? http://forums.cobbtuning.com/forums/showthread.php?t=36743 Link to comment Share on other sites More sharing options...
dbrunone Posted June 28, 2008 Share Posted June 28, 2008 I guess my next question is....is ecuexplorer sufficient? If yes, what parameters should I be logging so I can post here to get feedback? I'm no expert but.... RPM Engine Load Manifold pressure (PSI) Advance (Timing) Knock (digital) AFR Intake air temp MAF flow? Anything else??? Link to comment Share on other sites More sharing options...
NatesGr8 Posted June 28, 2008 Share Posted June 28, 2008 subscribe Link to comment Share on other sites More sharing options...
Infamous1 Posted June 28, 2008 Share Posted June 28, 2008 I guess my next question is....is ecuexplorer sufficient? If yes, what parameters should I be logging so I can post here to get feedback? I don't use ECUExplorer for logging so I had to go connect to the car to see what parameters are there. With ECUExplorer log the following: Engine speed(RPM) Throttle Opening Angle(%) Mass Air Flow(g/s) Ignition Timing Knock Correction Manifold Relative Pressure(PSI) Primary Wastegate Duty Cyle(%) This will allow us to see how your tune is working on your car. Link to comment Share on other sites More sharing options...
Jon in CT Posted June 28, 2008 Share Posted June 28, 2008 im looking for something that will work with my APv2 CAN cable...ecuExplorer is ok, but super super buggyWhy not just use RomRaider and one of those cheap Chinese knockoff VAG-COM cables from eBay? http://www.google.com/products?q=vag-com+kkl&scoring=p Link to comment Share on other sites More sharing options...
dbrunone Posted June 28, 2008 Share Posted June 28, 2008 ;1946969']Why not just use RomRaider and one of those cheap Chinese knockoff VAG-COM cables from eBay? http://www.google.com/products?q=vag-com+kkl&scoring=p Will that work with my car? Even though the cable is made for audi/vw/skoda or whatever? Will Romraider even recognize my ecu? Link to comment Share on other sites More sharing options...
Infamous1 Posted June 28, 2008 Share Posted June 28, 2008 Yes... Link to comment Share on other sites More sharing options...
Jon in CT Posted June 29, 2008 Share Posted June 29, 2008 If you have a 2007+ Legacy and decide to go the RomRaider route, you'll also want to download some special RomRaider definitions from http://www.romraider.com/forum/topic3021.html so that you can log IAM. Link to comment Share on other sites More sharing options...
Vsick Posted June 29, 2008 Author Share Posted June 29, 2008 ended up buying the vag com cable also...will log with ecu ecu explorer once the jbweld cures and stock tmic goes back into the carl Link to comment Share on other sites More sharing options...
Infamous1 Posted June 29, 2008 Share Posted June 29, 2008 ended up buying the vag com cable also...will log with ecu ecu explorer once the jbweld cures and stock tmic goes back into the carl If you brought the vag-com cable don't even bother with ECUexplorer log with RomRaider. Far superior logging software. Link to comment Share on other sites More sharing options...
