madabs Posted June 19, 2008 Share Posted June 19, 2008 Has anyone changed the horn. I have only had my LGT for a few months and after I used the horn for the first time I knew it had to go. I used it the other day and even my wife laughed about how fruity it sounded. I am embarrassed to use it. Its not all Japanese cars because my Maxima and Infiniti had decent horns. Link to comment Share on other sites More sharing options...
eqt2010 Posted June 19, 2008 Share Posted June 19, 2008 Hella Supertones FTW! Link to comment Share on other sites More sharing options...
Wang Lung Posted June 19, 2008 Share Posted June 19, 2008 http://www.legacygt.com/forums/showthread.php?t=65683 Link to comment Share on other sites More sharing options...
SSN666 Posted June 19, 2008 Share Posted June 19, 2008 Wimpy horns is exactly why I changed mine. They were barely audible on the freeway. I got a set of air-horns at Pep Boys that has the compressor and trumpets in one small unit. I mounted them behind the grill on the vertical bar ahead of the radiator. I moved the wire for the existing horn over. Because they draw more power than the regular horn is fused for, I tapped a line from the battery to a relay to the airhorns, then used the wire from the original horns to close the relay. If you have not tracked down the actual LGT horns. They are below the passenger side headlight (and so are muffled even more by being enclosed). Pull the air intake ducting and even the filter box and you should be able to see them. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted June 19, 2008 Share Posted June 19, 2008 I had 4 PA speakers welded to the car chassis. Two smaller ones pointing down near the bumper, one large one pointing down in the engine bay, and one smaller one pointing out the grille. Got that hooked up to a 240 watt amp in the trunk which, in turn, is hooked up to my carputer. Makes for ridiculously loud sounds as well as music and... PA system (though I don't use it for that since I think that's illegal... other than the occasional "STEP AWAY FROM THE VEHICLE" when any kids in my local neighborhood try to step on the back bumper for a ride down the street... lol.) Fun to do jet-turbine startup sounds in a parking lot and have people look and think (what the hell has he got under THERE?!?) Also fun to do funny musical horns. And if you really want to scare someone, I've got that annoying car alarm that changes tones, but if someone is within ten feet and I play that one, they pretty much get deafened. Link to comment Share on other sites More sharing options...
gone2vegas Posted June 19, 2008 Share Posted June 19, 2008 I got this one http://www.griotsgarage.com/product/car+accessories/exterior+accessories/red%2C+compact+italian+air+horns.do you can also just do a search on google for stebel nautilus. I mounted mine on the passenger side where one of the stock horns use to mount. pretty simple install. Link to comment Share on other sites More sharing options...
ih8vtec13 Posted June 19, 2008 Share Posted June 19, 2008 throw in super tones. They look great on a black car with a mesh grill and time attack style wheels. Link to comment Share on other sites More sharing options...
leggtnut Posted June 19, 2008 Share Posted June 19, 2008 I got this one http://www.griotsgarage.com/product/car+accessories/exterior+accessories/red%2C+compact+italian+air+horns.do you can also just do a search on google for stebel nautilus. I mounted mine on the passenger side where one of the stock horns use to mount. pretty simple install. Wow, that is really affordable. I just might get one. So did you disconnect both horns or just the passanger side one? Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
sooberoo Posted June 20, 2008 Share Posted June 20, 2008 I got this one http://www.griotsgarage.com/product/car+accessories/exterior+accessories/red%2C+compact+italian+air+horns.do you can also just do a search on google for stebel nautilus. I mounted mine on the passenger side where one of the stock horns use to mount. pretty simple install. I have a Nautilus in my Miata. Simple patch into the existing horn circuit. Unfortunately its also the same circuit for the brake lights. Get cut off, hit horn and brake at the same time and you blow a fuse! After about the third time I had the relay installed. No problems since and they are loud! Curious as to whether you installed a relay when you installed this horn. If not, any blown fuses? Link to comment Share on other sites More sharing options...
ih8vtec13 Posted June 20, 2008 Share Posted June 20, 2008 [ame=http://www.youtube.com/watch?v=DN5S91oCaPA]YouTube - Break Horn[/ame] Link to comment Share on other sites More sharing options...
gone2vegas Posted June 20, 2008 Share Posted June 20, 2008 I had the stock horn hooked up in the beginning but it got annoying so I disconnected it. I can't remember if I installed a relay, I'll have to take a look at it. Link to comment Share on other sites More sharing options...
ih8vtec13 Posted June 20, 2008 Share Posted June 20, 2008 I have 1 stocker hooked up still. You cant even hear it over the grill mounted Hellas. People get scared and move very rapidly when i hit them sometimes kids fall off their bikes too. Link to comment Share on other sites More sharing options...
outdoorlife85 Posted June 20, 2008 Share Posted June 20, 2008 Someone should do the train horn kit. http://videos.streetfire.net/video/Train-Air-Horn-Really_26323.htm Link to comment Share on other sites More sharing options...
uberwagon Posted June 21, 2008 Share Posted June 21, 2008 I got this one http://www.griotsgarage.com/product/car+accessories/exterior+accessories/red%2C+compact+italian+air+horns.do you can also just do a search on google for stebel nautilus. I mounted mine on the passenger side where one of the stock horns use to mount. pretty simple install. sweeeeeeeeeeeet !!!!!! I gotta get this !!!! Nice find !! Link to comment Share on other sites More sharing options...
Jon in CT Posted June 21, 2008 Share Posted June 21, 2008 Here ya go. [ame=http://www.youtube.com/watch?v=q0pf_0cFbVo]YouTube - La Cucaracha horn[/ame] Link to comment Share on other sites More sharing options...
Strabismo Posted June 22, 2008 Share Posted June 22, 2008 ^^ I like the thumbs up pause after Link to comment Share on other sites More sharing options...
ehsnils Posted June 22, 2008 Share Posted June 22, 2008 Ice cream horn... Link to comment Share on other sites More sharing options...
DocHolladay23 Posted August 30, 2008 Share Posted August 30, 2008 THREAD REVIVAL! Just thought I'd post a vid of my new Stebel Nautilus horn, in stock location: [ame=http://www.youtube.com/watch?v=Jq-c8SpiXVc]YouTube - Stock Subaru Horn VS. Stebel Nautilus[/ame] [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
legacy3R Posted August 30, 2008 Share Posted August 30, 2008 Someone should do the train horn kit. http://videos.streetfire.net/video/Train-Air-Horn-Really_26323.htm A buddy of mine has a GMC dually that he uses to haul his boats and they have it all hooked up, including train horns. Thats the best part about driving that truck. I have had so much fun driving through the city and scaring people walking down the sidewalk. If I could get something like that in my car, that would be great. Link to comment Share on other sites More sharing options...
Dan007CT Posted August 31, 2008 Share Posted August 31, 2008 I got a Whelen electoric air horn. LOVE it. $200. 100 was the speaker, the other 100 was the unit. rigged it to its own switch so the stock horn still works. Local audio place installed it for me Link to comment Share on other sites More sharing options...
