Ridgeracer Posted January 24, 2005 Share Posted January 24, 2005 Hey guys....I have about 6K on my Leg Gt manual and I have been having problems with the throttle every once in a while. The problem occurs when I am at a standstill and I put it into gear then lightly apply throttle. The car then applies more throttle than what I command therefore it pulls forward really hard. This is getting very dangerous so i'm going to take it to my dealer. Anyone else experience this problem..? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted January 24, 2005 Share Posted January 24, 2005 Mine seems to do that too- but only on hills and only every now and then. Link to comment Share on other sites More sharing options...
Deer Killer Posted January 24, 2005 Share Posted January 24, 2005 can you hear the engine when you are doing this? Link to comment Share on other sites More sharing options...
Ridgeracer Posted January 24, 2005 Author Share Posted January 24, 2005 a little but it just jumps...kinda scarey. I have to get back on the clutch and hit the brakes. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
gmorris Posted January 24, 2005 Share Posted January 24, 2005 Mine does a similar thing all the time in stop and go traffic. Ease the clutch out under very gentle throttle to pull forward slightly, let my foot off the throttle as I come up to the guy in front but the revs don't drop. Seams to be a ~1 second delay before the throttle actually lifts...almost caused me to nudge the car in front the first couple times. Still catches me by surprise every now and then. Only seams to happen when I use very light throttle, almost like there is a threshold of maybe 5% throttle and the delay is eliminated if you pass it. Link to comment Share on other sites More sharing options...
jmcgliss Posted January 24, 2005 Share Posted January 24, 2005 I've noticed that too...rate of accleration seems more than what the throttle position alone would indicate. Does the by-wire 'software' respond more aggressively if the **speed/rate** of pedal depression is somewhat quick? e.g. push to pass vs. accelerate slowly to cruising speed. JC, Chicagoland bassist & opentracker 2005 LGT 5MT Ltd wagon 2005 LGT 5MT Ltd sedan Link to comment Share on other sites More sharing options...
mwiener2 Posted January 24, 2005 Share Posted January 24, 2005 If you have just been doing some spirited driving, the ECU is in it's "spirited" learnign map. So when you stop and start to go, it's still in that map and needs a little bit of tiem to swtich to a less aggressive map. I notice this alot with my mom's mercedes. When i get in it, the first 20 miles or so are horribly sluggish, cause my mom drives like someones mom. Then after i get into an aggressive map and she gets back in, she thinks someone spiked her gas or something. Could also be something to do with the shudder, studder, hiccup everying is having at low revs. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted January 24, 2005 Share Posted January 24, 2005 Hmm- and here I thought originally that the car knew it was on a hill somehow and was giving extra gas so as not to stall. Link to comment Share on other sites More sharing options...
rao Posted January 24, 2005 Share Posted January 24, 2005 Same here. I think the ECU reads the speed that the throttle opens and sometimes assumes you want to go faster then you want when creeping forward. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
racerdave Posted January 24, 2005 Share Posted January 24, 2005 Anyone know if the Accessport fixes this "feature?" If so, that's be reason enough to get it... Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted January 24, 2005 Share Posted January 24, 2005 Actually, now that you mention it, I haven't seen it since installing the AP. Link to comment Share on other sites More sharing options...
Ridgeracer Posted January 26, 2005 Author Share Posted January 26, 2005 Hummm...I recall someone asking the guys at Vishnu about lowering the throttle latency from 500ms with the Ecutek and they said it can be easily done. At the time I didn't realize the significance of this. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Ridgeracer Posted January 26, 2005 Author Share Posted January 26, 2005 BTW...since everyone seems to have this problem and I truely doubt the dealer has a fix i'll save myself the trip. Now did anyone's HVAC blower motor freeze like mine in the cold? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
dbwillis Posted January 26, 2005 Share Posted January 26, 2005 I noticed this as well, a delayed release of the throttle when only applying a tiny bit of it Link to comment Share on other sites More sharing options...
Xenonk Posted January 26, 2005 Share Posted January 26, 2005 Here I thought it was the Dual Mass Flywheel. Keefe Keefe Link to comment Share on other sites More sharing options...
Mr. CentralOhioSubarus Posted February 3, 2005 Share Posted February 3, 2005 Yes, this happened to me only once. It's definately not the flywheel. I know the difference. Link to comment Share on other sites More sharing options...
