morrisok Posted June 12, 2008 Share Posted June 12, 2008 I have been stutter free since I went Stg2 a year and a half ago. This was the case with the COBB ots maps and my protune. I rarely use cruise control but noticed tonight on the interstate that there is a bit of stutter/hesitation when cruising between 65-70 and cruise control is set/on. I havent tried this with a Stg1 COBB ots map but might test it this weekend and do some logging. Anyone else experience this? Link to comment Share on other sites More sharing options...
UniqueTII Posted June 12, 2008 Share Posted June 12, 2008 I have the same issue and from what I've read it's caused by a failing front oxygen sensor which causes the ECU to hunt for the proper A/F ratio which in turn causes surging. Link to comment Share on other sites More sharing options...
schneiks Posted June 12, 2008 Share Posted June 12, 2008 ^^^^ is that covered under warranty? Coincidentally I had this happen to me just last night....I thought it was because I had my spare tire on. Link to comment Share on other sites More sharing options...
PyrosDesign Posted June 13, 2008 Share Posted June 13, 2008 When you talk about stutter what are you referring to? I have a bit of a hesitation (intermitten, no set rpm but i notice it most under hard acceleration, and no set gear.) Wondering if this is what your talking about since both of you own the 06 also. My dealer said they CND my problem 2 different times, so i stopped dealing with them,so any info will help. Link to comment Share on other sites More sharing options...
UniqueTII Posted June 13, 2008 Share Posted June 13, 2008 What I'm talking about is a surging at a constand RPM (usually between 2-3K for me). Link to comment Share on other sites More sharing options...
morrisok Posted June 13, 2008 Author Share Posted June 13, 2008 That sounds like exactly what I am experiencing too!! I guess it is more of a surge than a stutter. With regards to warranty coverage I am not so sure they will cover it being Stg2 and all. I was told on my 30K service that my car "had been flagged by Subaru" because of my UP/DP and removal of two of the cats (in the stock UP and one in the DP). I guess it would matter from dealer to dealer. Link to comment Share on other sites More sharing options...
drcaveman Posted June 13, 2008 Share Posted June 13, 2008 warranty can only be denied if SOA can prove the mods are responsible for the part failure. This I believe a federal law. Link to comment Share on other sites More sharing options...
Underdog Posted June 13, 2008 Share Posted June 13, 2008 warranty can only be denied if SOA can prove the mods are responsible for the part failure. This I believe a federal law. As a side note, the service manager told me this morning that installing spec.b trailing arms in a GT is grounds for having my warranty voided. I told him that a Subaru warranty is about as useful as a perforated condom. The Crimson Dynamo Link to comment Share on other sites More sharing options...
