Andreu Posted May 3, 2008 Share Posted May 3, 2008 I want to tuck my stock exhaust and was wondering how i should do it. Link to comment Share on other sites More sharing options...
NewLegGT67 Posted May 3, 2008 Share Posted May 3, 2008 Bend the metal from the muffler that goes into the rubber hangers so the exhaust tips sit higher and maybe get some a/m exhaust hangers (Kartboy, Rallitek & Cusco) because they are made of polyurethane. The stock rubber ones are not that strong. Some members have bent the metal from the mufflers to the desired location and wrapped the stock rubber hangers with some metal zipties, which also work. I'm probably the only person that has Wu-Tang Clan and Paul McCartney on their mp3. Link to comment Share on other sites More sharing options...
devobuzz Posted May 3, 2008 Share Posted May 3, 2008 To tuck the mufflers closer to the cutouts, I just used the other hole in the rubber hanger. Link to comment Share on other sites More sharing options...
Andreu Posted May 4, 2008 Author Share Posted May 4, 2008 To tuck the mufflers closer to the cutouts, I just used the other hole in the rubber hanger. Do you do that for both hangers or just the one pictured. Link to comment Share on other sites More sharing options...
Spec B Posted May 5, 2008 Share Posted May 5, 2008 Or you could use a heavy duty tie strap to pull them up a bit. Link to comment Share on other sites More sharing options...
SubLGTaru Posted May 5, 2008 Share Posted May 5, 2008 I also want to know if you do that for both hangers? Right now my HKS exhaust hangs lower on the passenger side than it does on the driver side. I guess I will play around with it and see if doing that to the passenger side only will even it up. Link to comment Share on other sites More sharing options...
devobuzz Posted May 6, 2008 Share Posted May 6, 2008 I did for both hangers. Once you tuck it closer to the valence, you'll be able to notice the difference between the two sides more easily though. Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted May 6, 2008 Share Posted May 6, 2008 Do you do that for both hangers or just the one pictured. Does your GF's bra have half an under wire if she wants to lift both tits? OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
SubLGTaru Posted May 7, 2008 Share Posted May 7, 2008 what if one hangs lower than the other? :lol: Link to comment Share on other sites More sharing options...
Andreu Posted May 7, 2008 Author Share Posted May 7, 2008 Does your GF's bra have half an under wire if she wants to lift both tits? HAHAHAHA. Point made. I get it now Link to comment Share on other sites More sharing options...
