xt2005bonbon Posted October 22, 2014 Share Posted October 22, 2014 do the usual suspects: swap coils. see if misfires follow. if not. swap injectors. see if misfires follow. if not, assess spark plug condition. if coil, injector, plug are OK, then time for a compression/leakdown test. May be in need of valve adjustment or bad ringland.. Link to comment Share on other sites More sharing options...
drunkinmonk Posted November 5, 2014 Share Posted November 5, 2014 I got a p0301 after a few mile of my downpipe install and cobb ap stage 2 tune. would this have happened if I just left my car at stage one cobb tune? Link to comment Share on other sites More sharing options...
compsurge Posted November 5, 2014 Share Posted November 5, 2014 Likely. Link to comment Share on other sites More sharing options...
drunkinmonk Posted November 5, 2014 Share Posted November 5, 2014 Stage 2 probably just accelerated the problem to show earlier. Well it's at the mechanic we'll have to hear back from him. Link to comment Share on other sites More sharing options...
drunkinmonk Posted November 7, 2014 Share Posted November 7, 2014 It was a bad coil pack. Back up and ruining! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 7, 2014 Share Posted November 7, 2014 Do you know if the back of the coil pack looked bulged? Or did its outside appearance looked normal? Link to comment Share on other sites More sharing options...
compsurge Posted November 7, 2014 Share Posted November 7, 2014 It was a bad coil pack. Back up and ruining! QFT. It's only a matter of time on these engines Link to comment Share on other sites More sharing options...
drunkinmonk Posted November 7, 2014 Share Posted November 7, 2014 QFT. It's only a matter of time on these engines Already blew once. Got about 35k on this new rebuild done by the dealer. Link to comment Share on other sites More sharing options...
drunkinmonk Posted November 7, 2014 Share Posted November 7, 2014 Do you know if the back of the coil pack looked bulged? Or did its outside appearance looked normal? Not sure I had my mechanic replace it. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 7, 2014 Share Posted November 7, 2014 I replaced both OCV and my misfires went away. used tatrix cable and watched the 2 vales related to OCV metric on each bank. Noticed 1 bank was not keeping up or getting stuck, compare to the other. I just replace both at same time. I'm new to the tactrix cable but how can I view these values? Link to comment Share on other sites More sharing options...
compsurge Posted November 7, 2014 Share Posted November 7, 2014 RomRaider. Check the tuning subforum stickied thread. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 7, 2014 Share Posted November 7, 2014 ^Simple fix on the wiring harness...... Pull the yellow tab on the connector plastic. Pop the pins out and insert them in the new plastic and then reinsert yellow tab http://www.ebay.com/itm/Subaru-Ignition-Coil-Wire-Harness-Terminal-Plug-Set-Impreza-WRX-STi-Connector-/300843950050?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ASubaru&hash=item460bb25fe2&vxp=mtr Nice I just broke my tab today as well! Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 8, 2014 Share Posted November 8, 2014 OK I pulled the cable to the injector for #2 and the injector must of been working because it made the car stumble.. nevertheless I finally got Romraider to work so I did a little logging. Maybe I'm missing something else to log?romraiderlog_20141108_072847.csv Link to comment Share on other sites More sharing options...
compsurge Posted November 8, 2014 Share Posted November 8, 2014 Try cleaning the injectors by removing the screens on them. I had some particulate in mine at 100k miles. Also run some Techron through a few tanks to see if that helps. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 8, 2014 Share Posted November 8, 2014 Try cleaning the injectors by removing the screens on them. I had some particulate in mine at 100k miles. Also run some Techron through a few tanks to see if that helps. I did not know you could remove the screens on them. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 8, 2014 Share Posted November 8, 2014 I just took the plug out for #2 and this is what it looks like vs new.. stupid me forgot my gap tool before I left this morninghttp://tapatalk.imageshack.com/v2/14/11/08/5c79328d0fba939be87e49c76c342616.jpg Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 8, 2014 Share Posted November 8, 2014 Well plugs did not help so it's compression test time Link to comment Share on other sites More sharing options...
compsurge Posted November 9, 2014 Share Posted November 9, 2014 I did not know you could remove the screens on them. Mine popped off when playing with them. I guess that makes them removable  They did pop back on too. I want to build a cleaning rig like the kind I see on YouTube where the injectors are put on a bench and run forward and reverse flow with injector cleaner. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 9, 2014 Share Posted November 9, 2014 Lol stupid me got my cylinders mixed up.. The injector is not spraying at all.. I pulled it at idle and nothing.. so how I got cylinder 3 and 2 mixed up is beyond me lol Link to comment Share on other sites More sharing options...
Brian3676 Posted November 9, 2014 Share Posted November 9, 2014 Lol stupid me got my cylinders mixed up.. The injector is not spraying at all.. I pulled it at idle and nothing.. so how I got cylinder 3 and 2 mixed up is beyond me lol I have not read through this thread, but are you sure you have spark in the cylinder? Pulling the injector is a classic trick to see if the cylinder is working, but after finding that its not, you still need to figure out spark, or fuel Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 9, 2014 Share Posted November 9, 2014 I have not read through this thread, but are you sure you have spark in the cylinder? Pulling the injector is a classic trick to see if the cylinder is working, but after finding that its not, you still need to figure out spark, or fuel When I get home I can put the new coil on the right side of the car.. but unless the car still fires the plug with no fuel or disables the injector I'm still ruling out as a bad injector.. I did not show all the plugs but 2 was more wet then all the others. I won't really get home till like 4pm so it's going to be awhile... it's killing my gas milage.. down to 14.2 mpg and only getting 160 miles from the tank Link to comment Share on other sites More sharing options...
compsurge Posted November 9, 2014 Share Posted November 9, 2014 Are you running rich or having rough starts? It could be an injector is stuck fully open or leaking. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 9, 2014 Share Posted November 9, 2014 Had nether it just happened while passing.. I won't say much more till I get home.. I mean they have almost 194k on them Link to comment Share on other sites More sharing options...
Brian3676 Posted November 9, 2014 Share Posted November 9, 2014 Yes the car will still fire that plug. If your dumping gas in (aka stuck open injector) your oil will smell like gas usually. If this is the case, careful you dont wash the cylinder walls or your gonna be replacing the engine. You can also try swapping injectors while your in there looking at the coil. There not too hard to swap. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 9, 2014 Share Posted November 9, 2014 The car does smell very rich at idle I have a strong fuel smell I don't mind having to change the oil early again only 1000 miles on it Link to comment Share on other sites More sharing options...
