SubLGTaru Posted March 27, 2008 Share Posted March 27, 2008 I just started noticing a creaking noise coming from my clutch pedal every time I shift. What could the cause of this be? Why would my car be doing this with only 17000 miles on it? Link to comment Share on other sites More sharing options...
SubLGTaru Posted March 27, 2008 Author Share Posted March 27, 2008 I just noticed it 2 days ago and it was pretty quiet, now on my way to work this morning it is a lot louder and more noticeable. Again it happens every time I shift. Link to comment Share on other sites More sharing options...
Legacy05 Posted March 27, 2008 Share Posted March 27, 2008 If its like a squeeking noise, it might be normal ... I know that sounds messed up, but mine squeeks and crunches from time to time. Link to comment Share on other sites More sharing options...
SubLGTaru Posted March 27, 2008 Author Share Posted March 27, 2008 well, I haven't heard the sound ever before, until just a couple days ago....and the sound seems to be intensifying day by day...today it was the loudest. Would oiling or greasing the clutch arm or pedal help? Link to comment Share on other sites More sharing options...
chenc544 Posted March 27, 2008 Share Posted March 27, 2008 http://www.legacygt.com/forums/showthread.php?t=77204 Link to comment Share on other sites More sharing options...
Levish Posted March 27, 2008 Share Posted March 27, 2008 I believe it's the throw out bearing, if its squeaking when you have the clutch pedal out and stops when you have the pedal in I've got a squeak that happens when actually pushing or releasing the clutch pedal which is just a sign of needing some lube/grease somewhere Link to comment Share on other sites More sharing options...
SubLGTaru Posted March 27, 2008 Author Share Posted March 27, 2008 No, I don't hear the creaking sound when the car is running. It only happens when I press the clutch pedal in and engage the pedal it creaks then I let it out and it drives normal. It is pretty much ever time I shift when I press down on the clutch pedal it creaks and it's gone.... I know what a bad throwout bearing sounds like, it hisses as you drive, I had that happen to my old civic si. It's not the throwout bearing. Link to comment Share on other sites More sharing options...
Underdog Posted March 27, 2008 Share Posted March 27, 2008 I've got a squeak that happens when actually pushing or releasing the clutch pedal which is just a sign of needing some lube/grease somewhere IIRC, there is a replacement for the clutch pedal switch to address squeaking. I remember reading about it a while back, and will try to search fr the thread. I only notice it when it's very quiet, car off for example. Also seems to be slightly worse in very cold temps. The Crimson Dynamo Link to comment Share on other sites More sharing options...
eldiablo Posted March 27, 2008 Share Posted March 27, 2008 Mine started squeaking around the 20k mile mark and then stopped squeaking around 30k... Very common complaint... http://www.legacygt.com/forums/showthread.php?t=5836&highlight=clutch+squeak My VB Garage... Pumping the air back into despair Link to comment Share on other sites More sharing options...
SubLGTaru Posted March 27, 2008 Author Share Posted March 27, 2008 I believe it's the throw out bearing, if its squeaking when you have the clutch pedal out and stops when you have the pedal in I've got a squeak that happens when actually pushing or releasing the clutch pedal which is just a sign of needing some lube/grease somewhere Yes, this is exactly what mine does. I can even hear it with the radio on and while driving the car. Every time I engage the clutch to change gears, it makes the creaking sound. I may try lubing the pedal or the arm and see if it will stop. Link to comment Share on other sites More sharing options...
chenc544 Posted March 27, 2008 Share Posted March 27, 2008 ^^ Read the last page of this thread regarding lube location. http://www.legacygt.com/forums/showthread.php?t=77204 Link to comment Share on other sites More sharing options...
fweasel Posted March 27, 2008 Share Posted March 27, 2008 I had the clutch switch replaced on my car last year for the same issue you're describing. Some dealers will want to try and lube the clutch pedal assembly which may cure it for a while, but unless the switch is replaced, it will come back. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
SubLGTaru Posted March 27, 2008 Author Share Posted March 27, 2008 How do I convince my dealer that the clutch switch needs to be replaced??? Link to comment Share on other sites More sharing options...
fweasel Posted March 27, 2008 Share Posted March 27, 2008 How do I convince my dealer that the clutch switch needs to be replaced??? show some leg. They wanted to replace my clutch fork. I suggested the switch as it had been replaced in other legacies with the same issue. I made a post somewhere with the part numbers on my invoice. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
SubLGTaru Posted March 27, 2008 Author Share Posted March 27, 2008 okay, I'll try digging that up. Link to comment Share on other sites More sharing options...
fweasel Posted March 27, 2008 Share Posted March 27, 2008 choke on this ignore him, he'll go away. Link to comment Share on other sites More sharing options...
Crawdaddy79 Posted March 28, 2008 Share Posted March 28, 2008 Mine has been creaking and squeaking since ~500 miles. It's on and off. I'm waiting until I get to about 55k miles before I bring it in for warranty replacement (hopefully by then it will be "on" instead of "on and off"). Link to comment Share on other sites More sharing options...
Crawdaddy79 Posted March 28, 2008 Share Posted March 28, 2008 You should stop driving with your goblin mask on then. Link to comment Share on other sites More sharing options...
SubLGTaru Posted March 28, 2008 Author Share Posted March 28, 2008 Yes, the creaking comes from inside the car....not outside. So there is no scaring the little children with my clutch, but maybe with my HKS Exhaust. Thanks for the link fweasel. Link to comment Share on other sites More sharing options...
