sschmelcke Posted March 23, 2008 Share Posted March 23, 2008 is the cat in the downpipe mainly used for when the car is cold? only reason i ask is im sure the main cat still does its thing when warmed up and we have somewhat strict emmisions. i just wanna make sure if i get a catless downpipe that i will still pass Link to comment Share on other sites More sharing options...
LGT Dave Posted March 23, 2008 Share Posted March 23, 2008 What kind of catless DP are you talking about? If you get a full-length catless DP (most of them are), it's actually getting rid of 2 cats and there wouldn't be any cats at all after the turbo. If you get a shorty DP (like a Crucial of Flow) then you would still have a stock cat in the mid-pipe. The cat that is mainly used for when the car is cold is in the uppipe (before the turbo). If you're concerned about passing emission tests, your best bet would probably be to just get a DP with a high-flow cat in it. Link to comment Share on other sites More sharing options...
sschmelcke Posted March 23, 2008 Author Share Posted March 23, 2008 yeah i was talking about a full length. the catted ones are so expensive so i was thinking about going catless. i think our new emmisions tests just checks for codes. we just recently changes so im not sure. if i get a shorty DP would i still be able to flash stage 2 without any issues? Link to comment Share on other sites More sharing options...
johnAWD Posted March 23, 2008 Share Posted March 23, 2008 Use a catted DP. Your planet will thank you. Link to comment Share on other sites More sharing options...
sschmelcke Posted March 23, 2008 Author Share Posted March 23, 2008 would a shorty DP be the same as using a catted DP Link to comment Share on other sites More sharing options...
Calcvictim Posted March 26, 2008 Share Posted March 26, 2008 I would think most places can't do a sniffer test since they need a 4wheel dyno, you should be fine with a cattless one as long as no check engine codes are tripped. Link to comment Share on other sites More sharing options...
sschmelcke Posted March 26, 2008 Author Share Posted March 26, 2008 i have an AP so i assume those codes are defeated? Link to comment Share on other sites More sharing options...
FoxHound Posted March 26, 2008 Share Posted March 26, 2008 if you do go catless, be warned, i have heard that sometimes you get the smell of gas in cabin of the car... i went catted to aviod that problem Link to comment Share on other sites More sharing options...
Calcvictim Posted March 26, 2008 Share Posted March 26, 2008 i have an AP so i assume those codes are defeated? the accessport will take care of codes, I am not exactly a tree hugger so my vote goes to saving a few hundred bucks. Link to comment Share on other sites More sharing options...
JonLGT Posted March 26, 2008 Share Posted March 26, 2008 would a shorty DP be the same as using a catted DP With a shorty you retain the 2nd (main) cat. So yes. Link to comment Share on other sites More sharing options...
