lowing springs... on a buget
sweetchaos
If you lower the car that much, the geometry will go south on you. Too much camber gain unless you run a lot of static camber.
For handling, the has a pretty low CG already. If you drop it much more then 20-25mm expect the body roll to go up in corners, not down.
Guest *Jedimaster*
I just remember in high school we would cut a piece of the spring out and it would lower the car/truck. We didn't have money to buy new springs.
hmm... I'll probably get the Tein springs.
I hope the factory struts are up to the job.
I've never just bought springs for a car... I always do a HUGE suspension make over when I mess with the footwork.
I'd like some 17" wheels first though
The only thing I don't like about the 2.5i is that it just doesnt look as aggressive as the GT because of the wheels.
I think springs and wheels will be just enough to get me through the 4 year lease :)
I dont wanna spend too much.
