bigb3630123 Posted March 11, 2008 Share Posted March 11, 2008 Anyone have an idea where to buy a new soft top for a 97' mustang? Or at least how much one would cost. He bought the thing dirt cheap with hardly any miles and in good shape besides the top wasn't taken care of properly so he has to replace it. thanks Link to comment Share on other sites More sharing options...
whitetiger Posted March 11, 2008 Share Posted March 11, 2008 http://www.duettomotors.com/general/tops/ford.htm I know the owner of the sire. he's a good guy. Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted March 11, 2008 Share Posted March 11, 2008 Might check and see if Robbins makes a replacement top that he likes. Robbins usually make better-than-OEM quality equipment, and are a favorite Miata replacement top, as well as replacement tops for classic cars. Something like that, I would upgrade under circumstances like that, if it has to be installed anyway. I will probably end up getting one of their better-than-stock tonneau covers, as the Miata's tonneau is unthreading at the seams, and the buttons are pulling out. If the top were to go, I would get a Robbins replacement. GLASS REAR WINDOW. ALWAYS A GLASS REAR WINDOW. Plastic is crap, gets creased, and cloudy in UV sunlight exposure, road grit and grime, and cleaning chemicals. plastic rear windows never last like glass does. You only have to be slightly more careful to fold the top easily, not harshly with a glass rear window. Glass windows, with or without zip-down, rear defrosters, better materials, including actual high-grade external canvas, and premium vinyl, and tauter patterns. Some designs actually have wider and larger rear windows which help with visibility and blind spots. The Miata version has a much larger glass rear window than the stock 99-05 NB rear glass window. http://www.robbinsautotopco.com/homepage.html 6211 - 1994-95 Ford Mustang Top, 3 Listings as orig. for 1994-95. Pre-drilled 8.0 24 1/2 9 alignment holes. 6212 - 1996-99 Ford Mustang Top, 2 Listings as orig. for 1996-99. Pre-drilled 8.0 24 1/2 9 alignment holes. 6213 - 2000-04 Ford Mustang Top, 2 Listings, Rubber Extrusions sewn above door glass 8.0 24 1/2 9 as original for 2000-04. Note: 6213 will also fit 1994-99 models. TN311 1994-04 Non-Heated Glass for 6211, 6212, 6213 Tops. 10.0# (O.S.)*15 HD311 1994-04 Heater/Defogger Glass for 6211, 6212, 6213 Tops. 10.0# (O.S.)*15 TN311 and HD311 Glass Windows have elastic straps and no zipper. Sharply curved glass is virtually identical to original. Glass Heatsealed into curtain. Pre-drilled alignment holes. PC6211 1994-04 Non-Original Plastic Window for 6211, 6212, 6213 Tops. Color trim. 10.0# 5 No zipper. 921L 1994-98 Headliner. Made with original style Plastic Extrusions. (HL VLB). 11.0# 4 922L 1999-04 Headliner. Made with original style Plastic Extrusions. (HL VLC with 11.0# 4 Foam Back). CABLES 6211 94-2/95 Mustang 94-2/95 Side Cables. Plate on one end Spring on other end, OAL: 35 1/8. 1 CABLES 6212 3/95-98 Mustang 3/95-98 Side Cables. Plate on one end Spring on other end, OAL: 35. 1 CABLES 6213 1999-04 Mustang 99-04 Side Cables. Plate on one end Spring on other end, OAL: 36 1/2. 1 CABLES 622 REAR 1994-04 Mustang 94-04 Quarter Flap Cables (pr). 1 Original Topping: 6211,6212 and 6213: 1994: Black/Black, Saddle/Black, Bright White/Black Pinpoint Grain Double Texture Vinyl. 1995-1996: Black/Black, Saddle/Black, Bright White/Black Sailcloth Grain Double Texture Vinyl. 1997-2004: Black/Gray, Saddle/Gray, Bright White/Gray Sailcloth Single Texture Vinyl. 921L Headliner: Black Velour Cloth. 1999-2004: Parchment/Gray replaced Saddle/Gray Sailcloth Vinyl. 2002-04 Cobra: Black and Med. Parchment Haartz Twillfast Cloth with Black Dobby backing. It looks like the later 200-2004 top with the sewn side window seals (6213) will directly fit in place of the non-sewn 96-99 style top (6212). That is probably the only difference, and might be a worth-while thing to look into, as well as the heated glass window option. Hope the info is helpful. Link to comment Share on other sites More sharing options...
John M Posted March 14, 2008 Share Posted March 14, 2008 I've helped swap the top on a friend's Mustang (95) before. It wasn't extremely difficult but it was time consuming. I'd set aside a full weekend just to make sure you aren't rushed. Link to comment Share on other sites More sharing options...
bigb3630123 Posted March 14, 2008 Author Share Posted March 14, 2008 thanks guys Link to comment Share on other sites More sharing options...
