pheonix991 Posted March 10, 2008 Share Posted March 10, 2008 I can't find much on this. I'm getting a 5speed from a 99 RS. I'm also getting the driveshafts. I've read about a guy doing a swap in his 22t legacy, seems everything bolts up for the most part, and only a few wires had to be messed with to get the ecu to make everything work properly. However, I don't know if this will be the same for my car. Will I need a new ecu? Or will the stock ecu work, and I just have to mess with the harness a little? Also, will the pedals fit? Link to comment Share on other sites More sharing options...
rao Posted March 10, 2008 Share Posted March 10, 2008 http://www.nasioc.com "Subaru conversions and hybrids" section Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
