oog61 Posted March 7, 2008 Share Posted March 7, 2008 When I changed my oil last week, the oil cap gasket remained stuck on the filler neck when I removed the cap. I peeled it off and then dropped it. I noticed that one side of the gasket is flat and the other is rounded. I'm not sure which side is supposed to go against the filler neck. The filler neck is flat so it seems like the flat side of the gasket should go against it, but if that is the case, why is the other side rounded? The inside of the cap where the gasket goes is also flat. Thanks. Link to comment Share on other sites More sharing options...
rao Posted March 7, 2008 Share Posted March 7, 2008 The rounded part goes down toward the motor; it helps to make a better seal Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
oog61 Posted March 7, 2008 Author Share Posted March 7, 2008 The rounded part goes down toward the motor; it helps to make a better seal Damn that was the fastest answer in recorded history. Thanks Rob Link to comment Share on other sites More sharing options...
andrew.anderson Posted March 7, 2008 Share Posted March 7, 2008 :lol: Link to comment Share on other sites More sharing options...
pillboy Posted March 7, 2008 Share Posted March 7, 2008 Mine did that once too. I was like WTF? NEVER have had that happen in 32 years of changing my own oil. However I did know which "side" went down. It is still ugly. Link to comment Share on other sites More sharing options...
