eatgeegee Posted March 6, 2008 Share Posted March 6, 2008 hi guys, i just wondering if 05+ legacy able to install an oem subwoofer under passenger side as well? any comments will be great help thank you Link to comment Share on other sites More sharing options...
eatgeegee Posted March 6, 2008 Author Share Posted March 6, 2008 anyone know? Link to comment Share on other sites More sharing options...
OGG Posted March 6, 2008 Share Posted March 6, 2008 Probably not if you want to have full range of motion for the seat. There's much less clearance than the drivers side. Link to comment Share on other sites More sharing options...
eatgeegee Posted March 7, 2008 Author Share Posted March 7, 2008 so only 1 subwoofer be allow under driver side seat then ? so no passenger at all unless do some modification? Link to comment Share on other sites More sharing options...
LGT Dave Posted March 7, 2008 Share Posted March 7, 2008 I've seen a few people with Spec.B's on here put the sub under the passenger seat because the stock navigation system sits under the driver's seat. It looked like the only modification that needed done was to bend the bracket that attaches the sub to one of the seat legs a little differently because it wasn't designed to be put on that side, or just use some velcro to hold it down. Link to comment Share on other sites More sharing options...
eatgeegee Posted March 8, 2008 Author Share Posted March 8, 2008 I've seen a few people with Spec.B's on here put the sub under the passenger seat because the stock navigation system sits under the driver's seat. It looked like the only modification that needed done was to bend the bracket that attaches the sub to one of the seat legs a little differently because it wasn't designed to be put on that side, or just use some velcro to hold it down. so i guess spec b would be allow to put another oem sub undernearth the passenger side , but not the legacy or LGT without modification then? Link to comment Share on other sites More sharing options...
OGG Posted March 8, 2008 Share Posted March 8, 2008 It might fit in a GT. I was figuring it wouldn't because my experience when I replaced the factory sub with a 2 channel amp. It's slightly bigger than the sub and it fit under the drivers seat but there was no way it was fitting under the passenger seat. Link to comment Share on other sites More sharing options...
eatgeegee Posted March 8, 2008 Author Share Posted March 8, 2008 alright, good reply OGG, i was about to purchase another oem subwoofer for the passenger side, now i know what to do , thank you Link to comment Share on other sites More sharing options...
TPLGT Posted March 8, 2008 Share Posted March 8, 2008 You have to flip the bracket inroder to do it. It is meant for the Driver's side. Rehab is for quitters. Link to comment Share on other sites More sharing options...
itsme Posted March 8, 2008 Share Posted March 8, 2008 I think the biggest problem is getting the pass seat bolts off. Mine need a specail tool. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
eatgeegee Posted March 9, 2008 Author Share Posted March 9, 2008 so i guess one oem subwoofer would be allow to install into 05 legacy eh ,just the driver side? the final answer? Link to comment Share on other sites More sharing options...
OGG Posted March 9, 2008 Share Posted March 9, 2008 I don't think there was a definite answer:p. The best thing to do is test it out. Find a book roughly the size of the sub and stuff it under there. Move the seat back and forth and see if it hits. Link to comment Share on other sites More sharing options...
JNRacing Posted March 9, 2008 Share Posted March 9, 2008 you don't need to use the bracket. Just might sure that the sub is secured by the double side tape they give you. Mine hasn't move seen I put it in without the bracket but mine is under the drive side. I had an old kit for a 01 Imprezza so my bracket didn't fit, that is why I didn't use the bracket. Link to comment Share on other sites More sharing options...
phenryiv1 Posted March 9, 2008 Share Posted March 9, 2008 How big is the optional OEM sub? Not speaker size- box size (H/W/D). Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
OGG Posted March 9, 2008 Share Posted March 9, 2008 10" x 8.5" x 2" give or take a 16th I just went out to the car and checked with the sub in my hand. Part of the seat frame interferes with sliding it all the way under the seat. From what I can tell it would have to be mounted further back than on the driver's side but the seat shouldn't hit it. Link to comment Share on other sites More sharing options...
eatgeegee Posted March 10, 2008 Author Share Posted March 10, 2008 10" x 8.5" x 2" give or take a 16th I just went out to the car and checked with the sub in my hand. Part of the seat frame interferes with sliding it all the way under the seat. From what I can tell it would have to be mounted further back than on the driver's side but the seat shouldn't hit it. hey OGG, so can you help me out to test fit the oem subwoofer see if the sub able to fit undernearth the passenger side? any hit ? Link to comment Share on other sites More sharing options...
OGG Posted March 10, 2008 Share Posted March 10, 2008 From what I can tell it can be done but it would have to be turned 90 degrees from how it mounts under the driver's seat or it would stick out pretty far. The bars that interfere are part of the frame that doesn't move under the seat and since the passenger seat doesn't go up and down it should fit. Personally I wouldn't bother with a stock sub. It's a joke:lol:. I put a Kenwood KSC SW1 in the cargo tray in my wife's '05 wagon and sounds SOOOO much better than the stock unit and has more output even buried in the back. Link to comment Share on other sites More sharing options...
eatgeegee Posted March 11, 2008 Author Share Posted March 11, 2008 From what I can tell it can be done but it would have to be turned 90 degrees from how it mounts under the driver's seat or it would stick out pretty far. The bars that interfere are part of the frame that doesn't move under the seat and since the passenger seat doesn't go up and down it should fit. Personally I wouldn't bother with a stock sub. It's a joke:lol:. I put a Kenwood KSC SW1 in the cargo tray in my wife's '05 wagon and sounds SOOOO much better than the stock unit and has more output even buried in the back. so i guess, the way of suppose to install at the passenger side will be different than the driver side if we consist to do it, and i dont think we suppose to put another oem subwoofer undernearth the passenger side seat anyways, for factory recommendation? we suppose need on the driver side for oem subwoofer? Link to comment Share on other sites More sharing options...
eatgeegee Posted March 11, 2008 Author Share Posted March 11, 2008 so the passenger side cant be install like driver side right? unless we move the bracket around? Link to comment Share on other sites More sharing options...
OGG Posted March 11, 2008 Share Posted March 11, 2008 That is correct. Link to comment Share on other sites More sharing options...
mylgt1 Posted March 25, 2008 Share Posted March 25, 2008 go to page 8 http://www.legacygt.com/forums/showthread.php?t=2084&page=8&highlight=oem+subwoofer Link to comment Share on other sites More sharing options...
