starla79 Posted March 2, 2008 Share Posted March 2, 2008 For a small amount of background, we're leasing an 05 LGT and the lease is up in October. We've been trying to decide what to get as a replacement, and after being told that our extended warranty doesn't cover the crappy brakes/rotors that had to be turned again (they were done about 12k miles ago -- less than a year) at our expense, I'm about sick of throwing money away on this car. I kind of want an 06 spec.B to replace it with (if i can find one) and I was wondering if they use the same soft rotors and brakes as the LGT does, or if Subaru put decent ones on the spec.B that we aren't going to have to replace right away. I read quite a bit about re-bedding here but have no idea where we could do such a thing around Atlanta... the roads around where we live have too much traffic to do it safely, so in the end we just paid to have the rotors turned and sure enough, the vibration goes away. I love Subaru's 'it's a feature, not a bug' attitude about stuff like this... no other car we've owned has had so many problems with the stock equipment being inferior and wearing out so quickly. And since it's a lease, it doesn't make sense to put on better brakes/rotors... if we got a spec.B we probably would, unless the stock equipment is better on those, which I'm hoping. Link to comment Share on other sites More sharing options...
PhilT Posted March 2, 2008 Share Posted March 2, 2008 Brakes are the same, if you want better brakes, change pads and lines. The OEM rotors are fine, mine have lasted over 80K, and only been turned once. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
camber Posted March 2, 2008 Share Posted March 2, 2008 Is your LGT an automatic? Link to comment Share on other sites More sharing options...
lkjohnson1950 Posted March 2, 2008 Share Posted March 2, 2008 40K on original pads and rotors, no problems. Plenty of threads on here about upgrading. Possible you have some other problem leading to premature wear? Most dealers' service departments are a joke, try to find a good performance shop to check your system. You're just jealous that the Voices talk to Me. Link to comment Share on other sites More sharing options...
fonts Posted March 2, 2008 Share Posted March 2, 2008 I have a Spec.B. No issues with brakes .... actually still running all original pads and rotors. Have 55,000 km+. Have not turned the rotors. That being said I do have replacement Hawk HPS pads and DBA 4000 rotors which will go on my car when I change to the summer setup. Link to comment Share on other sites More sharing options...
bgray Posted March 2, 2008 Share Posted March 2, 2008 Turning rotors is very counter productive in my mind. So the cost a good qaulity rotor, why bother. With spirited driving, and heavy braking, it becomes very easy to warp a thinned out amchined rotor. At least from my customers, turning is never the right route. Probably having so many issues due to them being cut to many times Link to comment Share on other sites More sharing options...
BigBlack-V Posted April 28, 2010 Share Posted April 28, 2010 I am looking at a set of stock used LGT pads,rotors and calipers with 28K on them for 250$ and I wanted to know if its worth the purchase? I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
BradyCat Posted April 28, 2010 Share Posted April 28, 2010 Not sure about '06, but the newer Spec.B's do have slightly larger and thicker rotors than the other GT's front and rear, everything else is the same 2013 Ford Taurus SHO 2009 Spec.B SWP Stg 2+ Airboy tuned 2010 Toyota Sequoia Platinum 5.7 Link to comment Share on other sites More sharing options...
BlackHole Posted April 28, 2010 Share Posted April 28, 2010 Not sure about '06, but the newer Spec.B's do have slightly larger and thicker rotors than the other GT's front and rear, everything else is the same This is incorrect. All pre-2010 Spec Bs and LGTs use the same brake rotors - check Brembo or DBA, they're the same part#. Kyle "BlackHole" Link to comment Share on other sites More sharing options...
Darkness of Death Posted April 28, 2010 Share Posted April 28, 2010 the aftermarket rotors are the same size/part number, not stock Link to comment Share on other sites More sharing options...
BradyCat Posted April 28, 2010 Share Posted April 28, 2010 This is incorrect. All pre-2010 Spec Bs and LGTs use the same brake rotors - check Brembo or DBA, they're the same part#. Well, not sure where you got that info, but my '09 brochure states this clearly and lists the specs. If you don't believe me I'll get the numbers.... 2013 Ford Taurus SHO 2009 Spec.B SWP Stg 2+ Airboy tuned 2010 Toyota Sequoia Platinum 5.7 Link to comment Share on other sites More sharing options...
BradyCat Posted April 28, 2010 Share Posted April 28, 2010 Numbers listed in this thread: http://legacygt.com/forums/showthread.php/lgt-and-spec-b-brakes-and-rotors-samei-136519.html **EDIT**correction** size differences shown are between the MY09 n/a models and the specB, no GT sizes are listed on the brochure - apparently no GT's (besides specB) were sold in Canada MY09 (my bad) 2013 Ford Taurus SHO 2009 Spec.B SWP Stg 2+ Airboy tuned 2010 Toyota Sequoia Platinum 5.7 Link to comment Share on other sites More sharing options...
