LandShark Posted December 31, 2004 Share Posted December 31, 2004 I visited StopTech www.stoptech.com in L.A. yesterday to let them make fit-up checks for brake lines and, hopefully in the future, BBK for the new Legacy GT. They said right away after checking the clearances with the stock LGT 17" wheels that a BBK would not fit inside the front wheels. It's just too tight already with the stock brake size. You can barely pass a finger between the calipers and wheel. They said a rear BBK would fit but there's no real purpose for doing the rear brakes without better front brakes (where most of the stopping work is done). I also found out that the BBKs that Cobb offers are just private-labeled StopTech brakes. Not that that's a bad thing. This explains why Cobb's website states that their BBK will not fit the stock front wheels but will fit the rear wheels. Too bad. They did measure the flex brake lines and should offer a brake line kit for the new LGT in the near future. I'll be getting the first kit for FREE for my time. While I was there they were fit-checking the BBK for the new Toyota X-Runner pickup truck that's supposed to have handling that rivals the 350Z roadster. The TRD package is another private-label deal with StopTech. Link to comment Share on other sites More sharing options...
LandShark Posted December 31, 2004 Author Share Posted December 31, 2004 Here's some pics Link to comment Share on other sites More sharing options...
axis008 Posted January 1, 2005 Share Posted January 1, 2005 Interesting about the TRD. How come StopTech is planning to do another BBK test fit for the Legacy when the Cobb ones are StopTech? Hopefully you get it free or cheap though when the time comes . -ben Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted January 3, 2005 Share Posted January 3, 2005 My question is, if the stock brakes will barely fit in 17" rims, why would one need BIGGER brakes? Doesn't diminishing returns come into effect at a certain point. at that level, adding another inch to the rotor diameter is adding quite a bit of pretty heavy metal. If it were me, I would be asking about better vented, thicker, slotted, drilled/chamfered, or two-piece rotors of the same diameter, with better calipers, and stainless lines. Being able to run a stock rim for winter use, or spare use would be worth it to me. With anything bigger, ya'd have to buy 5 aftermarket 18" rims, just to have one as a spare in the trunk, and run 18" even lower-profile snow tires. Or carry a can of fix-a-flat, and a AAA card, and take your chances, rather than a spare. Link to comment Share on other sites More sharing options...
grmorrow04 Posted January 12, 2009 Share Posted January 12, 2009 Why would you need 5 wheels? The spare isn't supposed to go on the front, which means if you get a flat in the front, you are supposed to put a wheel from the rear on the front and put the spare on the rear. You don't want the spare on the front since those are the steering wheels. Link to comment Share on other sites More sharing options...
MOMSWGN Posted January 12, 2009 Share Posted January 12, 2009 Get up Lazarus. Bringing this thread up from the dead. Link to comment Share on other sites More sharing options...
