meatwad Posted December 29, 2004 Share Posted December 29, 2004 Writing this post for my friend jerami1981. He is experiencing a problem getting his car re-aligned in that he is being told that there is no camber adjustment possible. Is this true? Thanks for any help you can pass this way. (He would be posting this if he was near a computer currently.) Link to comment Share on other sites More sharing options...
Deer Killer Posted December 29, 2004 Share Posted December 29, 2004 Not on the rear.. Yes I'm having the same problem now (you have to replace the subframe if it is bent) Link to comment Share on other sites More sharing options...
meatwad Posted December 29, 2004 Author Share Posted December 29, 2004 Not on the rear.. Yes I'm having the same problem now (you have to replace the subframe if it is bent) His problem is the passenger front. Do you know if the front camber is adjustable? Sorry, I should have made that a bit clearer to begin with. Link to comment Share on other sites More sharing options...
rao Posted December 29, 2004 Share Posted December 29, 2004 The front camber is definately adjustable. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
SBT Posted December 29, 2004 Share Posted December 29, 2004 Keefe - sounds like you're needed here. Here's the camber specs: Camber (Differences between RH and LH: 45' or less) 2.5i, 2.5GT −0°15'±0°30' OUTBACK 0°40'±0°30' Directions: 1) When adjusting the camber, adjust it to the specs listed above 2) Loosen the two self-locking nuts located at the lower front portion of strut. NOTE: When the adjusting bolt needs to be loosened or tightened, hold its head with a wrench and turn the self-locking nut. 3) Turn the camber adjusting bolt so that the camber is set at specification. NOTE: Moving the adjusting bolt by one scale changes the camber by approx. 0°15' SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
meatwad Posted December 29, 2004 Author Share Posted December 29, 2004 Thanks guys, that is what was needed... Unfortunately adjusting the camber will not be enough to solve the problem jerami was having...repair time Link to comment Share on other sites More sharing options...
