rs6er Posted January 12, 2008 Share Posted January 12, 2008 If I arm my alarm with the key fob while sitting in the car, ignition off, and then manually (switch by the inside handle) unlock the passenger door and open it, should the alarm go off? Mine doesn't. Panic button works though. Link to comment Share on other sites More sharing options...
RobE Posted January 12, 2008 Share Posted January 12, 2008 IIRC it takes the alarm 30 seconds to arm after you press the button. i would put one of the windows down, walk away for a little while, come back, reach inside and open the door. bingo, alarm should go off. http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
rs6er Posted January 12, 2008 Author Share Posted January 12, 2008 Door won't open from the inside if it's locked. Link to comment Share on other sites More sharing options...
Penphoe Posted January 12, 2008 Share Posted January 12, 2008 Arm your alarm, and go watch some TV, have a drink, go pee - do something for 30 seconds. Come back to your car, but do not use your key-fob to unlock your car. Put your key into the key hole on the driver's side door and unlock the door. Open the door. Your alarm should be going off. LaterZ! Darren!! Link to comment Share on other sites More sharing options...
nKoan Posted January 12, 2008 Share Posted January 12, 2008 Door won't open from the inside if it's locked. try to unlock it first. but the key is to wait 30 seconds. Link to comment Share on other sites More sharing options...
AreEyeSeeKay Posted January 12, 2008 Share Posted January 12, 2008 You'll know the alarm is ready to go off when the blinking pattern of the security light changes Link to comment Share on other sites More sharing options...
spect2k Posted January 12, 2008 Share Posted January 12, 2008 All better? My parking light button got hit once and was left on. I noticed it and began to walk back to the car. All of a sudden, the alarm went off. I wonder if that had anything to do with the parking light switch on top of the sw Link to comment Share on other sites More sharing options...
Carter Posted January 12, 2008 Share Posted January 12, 2008 Take a crow bar and force the door open, its the only real way. Link to comment Share on other sites More sharing options...
RobE Posted January 12, 2008 Share Posted January 12, 2008 Door won't open from the inside if it's locked. thats why you manually unlock it (through the window) first http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
rs6er Posted January 12, 2008 Author Share Posted January 12, 2008 Arm your alarm, and go watch some TV, have a drink, go pee - do something for 30 seconds. Come back to your car, but do not use your key-fob to unlock your car. Put your key into the key hole on the driver's side door and unlock the door. Open the door. Your alarm should be going off. LaterZ! Darren!! Thanks. Followed your procedure and the alarm went off (on?) Link to comment Share on other sites More sharing options...
RobE Posted January 12, 2008 Share Posted January 12, 2008 my method too complicated for you????? :lol: http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
Carter Posted January 12, 2008 Share Posted January 12, 2008 my method too complicated for you????? :lol: :lol: Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted January 12, 2008 Share Posted January 12, 2008 Use a rock! Link to comment Share on other sites More sharing options...
Gmoe Posted January 12, 2008 Share Posted January 12, 2008 1. Park, lock/arm and leave a window down. 2. Give me your address. 3. Go to bed and see if the car is still there in the morning. If it's still there in the morning, the alarm worked. If not, I win a Spec. B. Link to comment Share on other sites More sharing options...
CTATV Posted January 17, 2008 Share Posted January 17, 2008 Just got my spec B the alarm was off I just turned it on, question does the alarm arm on the first time you hit the lock on the fob. I realize if I hit the lock button three times the first two it just beeps but the third one it chirps the horn. does this have anything to do with arming the alarm or just to let the person know that they have already locked the car and should stop clicking the friggin button again and again? I know the master alarm on off is changed using my touch screen also as a side note where can I get one of the shock sensors for my car, how much do they cost, and can i install it myself? thanks Link to comment Share on other sites More sharing options...
Hanger Posted January 17, 2008 Share Posted January 17, 2008 open the hood, lock the car, and slam it close ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Voytech Posted January 17, 2008 Share Posted January 17, 2008 What you're referring to is the "car finder" feature. Basically in a busy parking lot, it is supposed to help you find your car without hitting the panic button. Link to comment Share on other sites More sharing options...
CTATV Posted January 17, 2008 Share Posted January 17, 2008 ^^^cool thanks to hanger, i dont know if that was for me I dont have a shock sensor i was looking into where to buy one from Link to comment Share on other sites More sharing options...
Woby Posted January 17, 2008 Share Posted January 17, 2008 Hey this is my first post on here but I have been lurking for a couple of weeks. CTATV - when I bought my '08 Spec B, the dealer (although not a rocket scientist) said that the first two times you hit the fob was to lock the doors and the third louder beep is forom arming the alarm. I am not sure if this is true or not? If so has anyone figured out a way that a person can adjust these settings? Link to comment Share on other sites More sharing options...
