Dakar95Matt Posted January 8, 2008 Share Posted January 8, 2008 We're up here near Pittsburgh, it hit 70 degrees today. Anywho, since the weather has been cooler the LGT's gas mileage has been noticeably worse. I attributed the drop off in MPG to winter gas, but I guess it's just the weather. With the cold weather my wife has been getting about 23-24MPGs, today with the weather being what it was she averaged 27.5 today. It just seems odd to me because my M3 is the exact opposite but not to the extremes that the LGT is. Link to comment Share on other sites More sharing options...
AreEyeSeeKay Posted January 8, 2008 Share Posted January 8, 2008 Its because the air is more dense when its colder out, therefore, wind resistance is higher. Of course, when it gets too hot, engine effiency begins to suffer. I think I read once in Car and Driver that the sweet spot for most cars is around 50 degrees. http://www.xenodochy.org/ex/abstract/mileage.html Link to comment Share on other sites More sharing options...
spect2k Posted January 9, 2008 Share Posted January 9, 2008 I have been getting about 21 mpg average so far in my spec B. I just got it 10/31 though, so it has been cold. Today was the warmest day that I have had it and I saw it hit 23.7! I thought I was crazy....must be the weather having the car not work as hard! Link to comment Share on other sites More sharing options...
deeslk Posted January 9, 2008 Share Posted January 9, 2008 I can confirm that have been getting better mileage the past two warm days vs the past month of cold, snowy weather (Toronto, Canada) 23mpg. Bad being 18mpg Link to comment Share on other sites More sharing options...
BoOCh_00_GT_Ltd Posted January 9, 2008 Share Posted January 9, 2008 Colder, denser air entering the engine = need for more fuel to maintain a 14.7:1 AFR, therefore less fuel economy results. Plus it takes 40 percent more fuel to run a cold engine than a warm one! Untill the coolant reaches operating temp, a higher percentage of fuel is consumed. so the longer it takes to warm up the coolant, say from 0 degees compared to starting at 70 degrees, the more fuel comsumed in that period. so even parking your car in a heated garage overnight, can help you save gas in the winter:). Link to comment Share on other sites More sharing options...
05GT Guru Posted January 9, 2008 Share Posted January 9, 2008 Thats correct, the computer thinks your gettign a shit ton of air so the it puts more gas into the engien to keep the A/F ratio good. Cold air does inprove horsepower though Link to comment Share on other sites More sharing options...
Metal2You Posted January 9, 2008 Share Posted January 9, 2008 Don't forget that your drivetrain components (differentials) are contracted and therefore rob more power when they're cold. Link to comment Share on other sites More sharing options...
franklin Posted January 9, 2008 Share Posted January 9, 2008 They add ethanol to the gas in the winter. To make the air cleaner Im told , problem is it makes your gas mileage suck. Link to comment Share on other sites More sharing options...
05GT Guru Posted January 9, 2008 Share Posted January 9, 2008 I only drove my supra once in the cold and it also still ahd the stock ECU with alot mroe power than stock, and when it was cold i would make too much power for the ECU and it would totaly cut my fuel off and the motor would bog Link to comment Share on other sites More sharing options...
Jack ffr1846 Posted January 9, 2008 Share Posted January 9, 2008 So I'll get better mileage when it warms up more?? I've only just filled up my second documented tank of gas and I'm already quite happy. 27mpg first one, 30mpg second one. I drive mosly in "I" and watch the gauge to maximize mileage. Tires are graspics with 40psi in them. 08 LGT MT5. jack Link to comment Share on other sites More sharing options...
one69chev Posted January 9, 2008 Share Posted January 9, 2008 when your engine is cold, the pcm system will go into an enrichment mode using various sensors---coolant temp, ambient air----and cause the fuel system to run richer, in order to allow for faster engine warm-ups....... Link to comment Share on other sites More sharing options...
BoOCh_00_GT_Ltd Posted January 11, 2008 Share Posted January 11, 2008 They add ethanol to the gas in the winter. To make the air cleaner Im told , problem is it makes your gas mileage suck. The ethanol is added to break up moisture in the fuel, and also to help the fuel atomize (break up into a fine mist) easier. it is harder for fuel to turn from a liquid to a gas form when it is colder, therefore some help is needed. the air entering the engine is only as clean as your air filter gets it:). Link to comment Share on other sites More sharing options...
Blue GT Posted January 12, 2008 Share Posted January 12, 2008 I as well have noticed this over the past few warm days up here in Maine. It does make me somewhat happy considering over half the year the temps are right around 45-55 (all spring/fall) Link to comment Share on other sites More sharing options...
