eVoMotion Posted December 24, 2004 Share Posted December 24, 2004 I did a forum search and have not seen a good overview thread of what favorite wash, wax and detail kits are. What do you have in your bucket of goodies?! Klasse - what? Micro weaving waffle cham? Cheers! Link to comment Share on other sites More sharing options...
XtremeCreations Posted December 24, 2004 Share Posted December 24, 2004 I was thinking the exact same thing... Would you guys recommend getting a fbuffing kit for a hand drill? Link to comment Share on other sites More sharing options...
liquidiq Posted December 24, 2004 Share Posted December 24, 2004 http://www.properautocare.com/ I've had very good service from these guys, and they actually answer your emails! Link to comment Share on other sites More sharing options...
gtguy Posted December 24, 2004 Share Posted December 24, 2004 http://www.griotsgarage.com I swear by their stuff. Kevin Link to comment Share on other sites More sharing options...
SBT Posted December 24, 2004 Share Posted December 24, 2004 Griots is great stuff and I regularly order from him. For finish I prefer Zaino Brothers http://www.zainostore.com/Merchant2/merchant.mvc Check out some of their gallery photos and you can quickly see why this stuff works so well. And the finish lasts quite a while too. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
dv8ingvector Posted December 24, 2004 Share Posted December 24, 2004 i use 3m hand glaze and or zymol on my 86ss but doing to much on are GTs paint is like polishing a turd will all that orange peal. zymol has some great kits kind of expensive though Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted December 24, 2004 Share Posted December 24, 2004 IBZainonazis Link to comment Share on other sites More sharing options...
iuksob03 Posted December 24, 2004 Share Posted December 24, 2004 Bump for http://www.properautocare.com. I use the Klasse twins and couldn't be happier. Easy application and removal for a lazy slug like myself. The only thing wetter than the look of the car will be your pants after it's done. Link to comment Share on other sites More sharing options...
c_hunter Posted December 24, 2004 Share Posted December 24, 2004 I agree, Klasse is the bomb. CRaig Link to comment Share on other sites More sharing options...
Opie Posted December 24, 2004 Share Posted December 24, 2004 I 2nd this: http://www.griotsgarage.com I swear by their stuff. Kevin Link to comment Share on other sites More sharing options...
Limeydriver Posted December 24, 2004 Share Posted December 24, 2004 Mequiar's NXT works very well on the Obsidian black. Link to comment Share on other sites More sharing options...
2Simpletons Posted December 26, 2004 Share Posted December 26, 2004 Long time ZAINO BROS. user here... Link to comment Share on other sites More sharing options...
Euclid Posted December 27, 2004 Share Posted December 27, 2004 I use Pinnacle products, which can be found on properautocare's site. Link to comment Share on other sites More sharing options...
myUsername Posted December 27, 2004 Share Posted December 27, 2004 Does anyone here use a pressure washer to wash their car? I bought one over the summer and noticed that they sell a concentrated solution for cars and boats. I know that car dealerships use a pressure washer, but how well does it clean the car and is it safe on the paint? Link to comment Share on other sites More sharing options...
SBT Posted December 27, 2004 Share Posted December 27, 2004 Depends, in a lot of respects, on the PSI output of the machine. I used a 3200 psi machine, dialed back to ~2400 psi with a straight 1" jet and it partially stripped the clear coat off of my alloy wheels and made them look like the attack of the killer spider webs. From everything I understand the car detailers are using the industrial versions dialed down to ~1500 psi or less. If you have any cracks in your paint or chips, the pressure can and does get under these and, in some cases, can unloosen entire strips of paint. It was probably bad paint anyway and would have eventually worked its way loose, but no sense speeding up that process. To answer your question, it's probably okay to use them on the paint, just make sure that you "test" the output at a given psi on someplace out of sight visually. These are particularly good at removing surface mud and grime but you just have to be careful. Also, our frameless windows are no match for HP water at any psi so just watch how and where you spray. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
