whitetiger Posted January 3, 2008 Share Posted January 3, 2008 i will, i just need to read up, i dont know anything about it really, but it could be fun. i need somewhere to have fun with the car without being scared of gettin a ticket. Just click on the link in my signature. Learn all you need to know. Link to comment Share on other sites More sharing options...
tougefox Posted January 3, 2008 Share Posted January 3, 2008 indeed tires first. My sway mod was a much more rewarding mod than the springs tho Link to comment Share on other sites More sharing options...
jmfspecb Posted January 3, 2008 Share Posted January 3, 2008 Here's a good thread on suspension mods for "our" cars done by Dan from Mach V tuning in Virginia. http://legacygt.com/forums/showthread.php?t=5941 Link to comment Share on other sites More sharing options...
smack Posted January 4, 2008 Share Posted January 4, 2008 what is everyones oppinion on the best sway bars/sway bar set up? Link to comment Share on other sites More sharing options...
TJF37 Posted January 4, 2008 Author Share Posted January 4, 2008 since this is starting to turn into more of a suspension mod thread, i might as well ask another qustioon being that i've learned alot in this thread already. I too want to know what people opinions are for the sway bar combination, but also want to know opinions on coilovers. More specifically looking for very little ride quality loss, but a good balance on improved handling. If that makes sense Link to comment Share on other sites More sharing options...
BoozeRS05 Posted January 4, 2008 Share Posted January 4, 2008 Start small, and work your way up.. I started with the JDM rear sway bar w/ stock links & mounts, which was a huge improvement from OEM. I'll upgrade my endlinks, and mounts over the next year, but I don't think I'll upgrade the sways anymore.. BUT, I'm installing Bilstein struts/Swift springs in the spring . If not, I might have gotten a F&R package w/ mounts and links.. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
tougefox Posted January 4, 2008 Share Posted January 4, 2008 Cobb seems to be the best from the reviews. I personally run cobb front and rear. I ran the rear first and it was fun, increased oversteer. I liked the front and rear combo tho car was much flatter and neutral. Link to comment Share on other sites More sharing options...
enkeiandmore Posted January 4, 2008 Share Posted January 4, 2008 Link to comment Share on other sites More sharing options...
TJF37 Posted January 5, 2008 Author Share Posted January 5, 2008 are you running the 25mm cobb sways with stock suspension, or would you recommend doing more suspension worh with the sways right away? Link to comment Share on other sites More sharing options...
MDW25gt Posted January 5, 2008 Share Posted January 5, 2008 Here's what I have done. New engine at 133k. (head gasket hosed me) Borla headers (second set) Stromung exhaust (expensive but high quality & great sound) K&N panel filter with air box opened up (best bang for buck, intakes are counter productive) Hawk HPS pads on front & back Brembo rotors OEM replacement front & back Goodridge braided stainless brake lines (did not really notice much improvement) Motul RBF 600 fluid KYB GR2 struts (good bang for buck) Outback sway bar on rear ($40 real good bang for buck) 190k miles Goodyear Eagles (good tires) Next I will do sway bar bushings and end links. In that order. Link to comment Share on other sites More sharing options...
MonkeyHermit Posted January 5, 2008 Share Posted January 5, 2008 are you running the 25mm cobb sways with stock suspension, or would you recommend doing more suspension worh with the sways right away? Those should be ok to do by themselves, but if you're getting the rear set, I recommend you also get either the Perrin or the AVO rear reinforcement brackets. Those are a must when upgrading the rear sway. Other than that, you can do other suspension stuff when you're ready. Link to comment Share on other sites More sharing options...
daver192 Posted January 5, 2008 Share Posted January 5, 2008 I run the cobb sway bar kit on my 05. The rear bar comes with stiffeners, and the front bar is just a skiff narrow. I have not had any endlink issues with front, but understand others have. After installation I noticed a considerable difference in the cars handling and stiffness. In short good bang for the buck to be had here. I also run KW V-2 coilovers heavy duty endlinks and upper strut tower mounts. The sway gave me the greatest change followed by the coilovers... Link to comment Share on other sites More sharing options...
TJF37 Posted January 5, 2008 Author Share Posted January 5, 2008 I was reading on cobbs website that it comes with heavy duty mounts... would those work in place of the reinforcement brackets? I'll read up more on the issues people have had with endlinks Link to comment Share on other sites More sharing options...
daver192 Posted January 5, 2008 Share Posted January 5, 2008 Hey TJF, they are reinforcement brackets. One is a plate that mounts to the back of the frame support itself, and the other connects to the sub frame and ties into the mounting bracket. AVO also offers a stiffener, but I am not so sure the cobb stiffeners are inadequate. heavy duty end links are always a good idea to run with heavy duty sways... I have had no problems with so far they have been on for several months and car is lowered via the coil overs which adds additional stress to the structural mounts and end links hope that helps. Link to comment Share on other sites More sharing options...
TJF37 Posted January 5, 2008 Author Share Posted January 5, 2008 thanks for the help! I'm really starting to realize how much i have to learn. I thought it would be easy because i know alot about vw, but didnt do much suspension work. This is a whole new world!!! Link to comment Share on other sites More sharing options...
smack Posted January 6, 2008 Share Posted January 6, 2008 if anyone knows i also posted this in the perrin pulley walkthrough, but how can i install it with a 4eat, im so pissed that its not as simple as i thought it would be. and another question, ive been told that a performance catback exhaust wouldnt help an NA car with horsepower that much, any chance that is true? Link to comment Share on other sites More sharing options...
enkeiandmore Posted January 6, 2008 Share Posted January 6, 2008 i actually tried to do the pulley myself also. but i ended up finding out that you need to take out the radiator and that kind of intimidated me so i ended up taking it to a friends place to get it taken care of. Link to comment Share on other sites More sharing options...
MDW25gt Posted January 6, 2008 Share Posted January 6, 2008 Hey TJF, they are reinforcement brackets. One is a plate that mounts to the back of the frame support itself, and the other connects to the sub frame and ties into the mounting bracket. AVO also offers a stiffener, but I am not so sure the cobb stiffeners are inadequate. heavy duty end links are always a good idea to run with heavy duty sways... I have had no problems with so far they have been on for several months and car is lowered via the coil overs which adds additional stress to the structural mounts and end links hope that helps. What type of end links did you switch to? bushing or bearing? brand? Thx Mike Link to comment Share on other sites More sharing options...
daver192 Posted January 6, 2008 Share Posted January 6, 2008 I used AVO heavy Duty in the rear and cusco in the front. I believe thier bushing mounts... I was concerned after adding the sways and coil-overs as the stock end-links were pretty spindly, Purchased from rallitec. Link to comment Share on other sites More sharing options...
daver192 Posted January 6, 2008 Share Posted January 6, 2008 if anyone knows i also posted this in the perrin pulley walkthrough, but how can i install it with a 4eat, im so pissed that its not as simple as i thought it would be. and another question, ive been told that a performance catback exhaust wouldnt help an NA car with horsepower that much, any chance that is true? watch the pipe size 2-1/4 is plenty for the automatic and you will gain a few horses... Go big 3'' and you will lose power Link to comment Share on other sites More sharing options...
D_J Posted January 7, 2008 Share Posted January 7, 2008 What about a high-flow air filter? This AVO I believe is made for the 2.5i non-turbo. http://rallitek.com/avohiflpafi.html As is with the stock filter I can really hear that Boxer rumble when I accelerate heavily. I wonder if this will help give it a little more kick. Link to comment Share on other sites More sharing options...
sp468732 Posted January 7, 2008 Share Posted January 7, 2008 Out of curiosity, has anyone tried this tuning software on a 2.5i? http://rallitek.com/rapeecu.html Rallitek says that it will work for a 05-08 2.5i. I wonder how much power could be made from this? Link to comment Share on other sites More sharing options...
whitetiger Posted January 8, 2008 Share Posted January 8, 2008 ^ i bet 5-10hp by itself tops. the point of that unit is to tune the mods you have done already. it becomes beneficial one you things like cams or other engine mods. Link to comment Share on other sites More sharing options...
tito_b0y Posted January 8, 2008 Share Posted January 8, 2008 I'm curious about the HKS Silent Hipower exhaust on a 2.5i. It just sounds so nice, but wondering how it'll sound on an N/A. Here's a clip on a GT [ame=http://www.youtube.com/watch?v=EdED_vum1hU]YouTube - 07 Subaru Legacy GT; HKS Silent Hipower[/ame] 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
BoozeRS05 Posted January 8, 2008 Share Posted January 8, 2008 Your best (maybe 'only' at this point) route is to go custom exhaust.. Anything over 2.5" will likely cause power to suffer. 2.25" is recommended for NA stg 1-2, 2.5" is recommended for NA stg 3(cams & the P6) & turbo kits, & 3" is not good.. That was the case with my 2.5RS. Someone plz correct me if I'm wrong.. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
