j255c Posted December 23, 2007 Share Posted December 23, 2007 anyone know where i can source a new front diff? Mine is going. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
Guest Posted December 23, 2007 Share Posted December 23, 2007 How do you know it's going? Link to comment Share on other sites More sharing options...
mwiener2 Posted December 23, 2007 Share Posted December 23, 2007 I highly doubt it's the front diff whatever your problems is My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
G.T.Subie Posted December 23, 2007 Share Posted December 23, 2007 hmmm Denial is your best friend Link to comment Share on other sites More sharing options...
IBEWMAN Posted December 23, 2007 Share Posted December 23, 2007 anyone know where i can source a new front diff? Mine is going.Splain please !! Link to comment Share on other sites More sharing options...
j255c Posted December 23, 2007 Author Share Posted December 23, 2007 having numerous symptoms from this page http://i67.photobucket.com/albums/h300/c0lbyj/diagnostics.jpg however, it could very well be something associated with my clutch/transmission. Just trying to see if anyone knows the price on one of these. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
mwiener2 Posted December 23, 2007 Share Posted December 23, 2007 Which ones? Oil Leakage = gear oil and is not likely from the differential as it is from the ENTIRE transmission.... if the oil is even gear oil Seizure = could be gears, front/center/rear diff, bearings, severly warped rotor, something stuck in brakes Damage = wouldn't know untill you pulled apart stuff Noises from shifting/starting = see seizure Noises when cornering = more likely a bearign than a diff My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
bull Posted December 23, 2007 Share Posted December 23, 2007 do you get front wheel hop on a turn? Link to comment Share on other sites More sharing options...
j255c Posted December 24, 2007 Author Share Posted December 24, 2007 yes, but once again my clutch assy is completely borked so im going to fix that first. And then move on from there. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
bull Posted December 24, 2007 Share Posted December 24, 2007 i think subaru only sells the diff's as 1 assembled unit. i destroyed the spider gear in my wrx rear diff. and the whole diff had to be replaced Link to comment Share on other sites More sharing options...
mwiener2 Posted December 24, 2007 Share Posted December 24, 2007 ^^ buddy in a wrx ground up his rear diff.... also just replaced the whole unit, not the guts This would be a good chance to put a LSD front in.... but it's probably not the diff anyways My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
j255c Posted May 1, 2008 Author Share Posted May 1, 2008 bumpski, so i put in the new clutch. Noises still there, mechanic said there is a lot of metal when he drained my transmission fluid. Car shifts smooth, noise is still apparent. Should i ride it out? My understanding is the transmission and front diff are one entire assembly. That really sucks. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
rao Posted May 1, 2008 Share Posted May 1, 2008 They are not one assembly - they do share one case. If there were real chiunks the problem is real and will not go away. The only way to know is to pull the transmission and split the case. It is possible that the spider gears in the front diff are damaged. If that is the case they will ultimately break completely. You can check this out with the car in the air. Take it to someone who knows what they are doing. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
j255c Posted May 1, 2008 Author Share Posted May 1, 2008 Also my front tires are very bald and the rears are almost perfect which leads me to believe i need another alignment, this is probably putting added stress on the center and front differential no? 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
rao Posted May 1, 2008 Share Posted May 1, 2008 Not on the front diff, but possibly on the center diff. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
harman.khinda Posted May 2, 2008 Share Posted May 2, 2008 Also my front tires are very bald and the rears are almost perfect which leads me to believe i need another alignment, this is probably putting added stress on the center and front differential no? I had opposite my rears had less tread than the front tires and I blew my rear diff. Would this situation put stress on the center as well? Link to comment Share on other sites More sharing options...
