Blue Posted December 16, 2007 Share Posted December 16, 2007 Started up my car this morning and the "Check Engine" light came on. The "Cruise" light is also flashing. The car seems to run fine, but cruise control isn't functioning. Has anybody got any idea what caused this? Before you ask... I filled up my car three days ago - so it's not the fuel filler cap. -Blue Link to comment Share on other sites More sharing options...
rao Posted December 16, 2007 Share Posted December 16, 2007 EVERY TIME that the CEL is on the cruise control light flashes - it is part of the drive by wire experience Pull the code and you will know what is going on. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Blue Posted December 16, 2007 Author Share Posted December 16, 2007 EVERY TIME that the CEL is on the cruise control light flashes - it is part of the drive by wire experience Pull the code and you will know what is going on. How do I pull the code? Thanks. -Blue Link to comment Share on other sites More sharing options...
stevezx10r Posted December 17, 2007 Share Posted December 17, 2007 Looose gas cap will create this. Had it happen on wifes Tribecca. Link to comment Share on other sites More sharing options...
sexylegacy Posted December 17, 2007 Share Posted December 17, 2007 How do I pull the code? Thanks. -Blue Blue, just run down to an Autozone or some other parts store and they'll usually have an OBDII analyzer that they'll plug into your system for free to run the codes. Usually if your car still runs fine and you have a CEL it means either your gas cap isn't tightened or you've got an O2 sensor dying. You might have had a misfire, but it's probably unlikely. Link to comment Share on other sites More sharing options...
NYsFinest Posted December 17, 2007 Share Posted December 17, 2007 Ive had this happen twice in my LGT. One time it was the gas cap. The other time it was on for a couple hours, later in the day it went off by itself after I parked the car and restarted it to use again. Car has ran fine since and this was months ago. Link to comment Share on other sites More sharing options...
08Flo Rida Posted December 17, 2007 Share Posted December 17, 2007 This happened to me, but i think it happened because my buddy plug the two wires together that are on the passenger side foot area that are supposed to be unplugged. I just took it to the dealership, and they said they fixed the problem but i think all they did was unplug the wire. Link to comment Share on other sites More sharing options...
Guest Posted December 17, 2007 Share Posted December 17, 2007 There is a built-in code reader on 05 LGT (I think only on 05). Just need to plug two wires tucked around fuse box. Search and you'll find appopriate thread. Link to comment Share on other sites More sharing options...
mr_edly Posted January 14, 2008 Share Posted January 14, 2008 http://legacygt.com/forums/showthread.php?p=1619888#post1619888 Link to comment Share on other sites More sharing options...
