1-3-2-4 Posted December 15, 2007 Share Posted December 15, 2007 when I had my forester I was able to get it over 120.. it was pointing pass 120 so it was like 123ish but with Vermont being so hilly it took awhile. I guess the H6 tops out about the same speed given it's a bit larger in displacement? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted December 15, 2007 Share Posted December 15, 2007 Actually the top speed governor cannot be taken out, at least by COBB or by enginuity or ecuflash, it can just be changed. The highest it can be is 186 mph. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
flyboy1649 Posted December 15, 2007 Share Posted December 15, 2007 Took my 08 LGT to 141 and had about 800-1000 left on the RPM....... What I meant to say was: "on a closed course, professional drive, and don't try this at home!" Link to comment Share on other sites More sharing options...
merchgod Posted December 15, 2007 Share Posted December 15, 2007 The highest it can be is 186 mph. With the 32-bit ECU (which would be all USDM LGTs), there's no limit on how high you can set the limiter. Well, there is a limit, but it is close to the speed of the expanding universe a microsecond after the big bang. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted December 16, 2007 Share Posted December 16, 2007 With the 32-bit ECU (which would be all USDM LGTs), there's no limit on how high you can set the limiter. Well, there is a limit, but it is close to the speed of the expanding universe a microsecond after the big bang. That is interesting. When I change it with COBB I believe that 186 is the max. I will have to revisit it with Enginuity. Nice to see you here merchgod. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
edkwon Posted December 16, 2007 Share Posted December 16, 2007 i wonder how many ppl with AP flashed cars are going to put that derestricted top speed to the test? Link to comment Share on other sites More sharing options...
kiyanichenko Posted December 16, 2007 Share Posted December 16, 2007 ^^me, i have a stage 1 flash, i took mine up to 160. in a closed area of course, so edkwon wouldn't bag on me because im under the age of 18. Link to comment Share on other sites More sharing options...
merchgod Posted December 16, 2007 Share Posted December 16, 2007 That is interesting. When I change it with COBB I believe that 186 is the max. I will have to revisit it with Enginuity. Well, I don't know about Cobb's software. They might have placed some artificial limit in their software for whatever reason - you'd have to ask them. With Enginuity, however, you could enter in 1,000,000 mph or more if you wanted to (speed limiter values are 32-bit float). There's a hard (fuel cut) and soft (throttle cut) speed limiter. One thing that should be noted is that the throttle cut speed limiter, which has a enable and disable value, should never be the same value. The enable value should always be greater than the disable value. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted December 16, 2007 Share Posted December 16, 2007 Well, I don't know about Cobb's software. They might have placed some artificial limit in their software for whatever reason - you'd have to ask them. With Enginuity, however, you could enter in 1,000,000 mph or more if you wanted to (speed limiter values are 32-bit float). There's a hard (fuel cut) and soft (throttle cut) speed limiter. One thing that should be noted is that the throttle cut speed limiter, which has a enable and disable value, should never be the same value. The enable value should always be greater than the disable value. Correct you are. COBB generic stage 2 map has a speed limiter of around 554 mph. If I try and change it the max I can to is 186. Those guys sure rip you off. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Grimace Posted December 16, 2007 Share Posted December 16, 2007 ok this might be an old question or not known but what is the actual top speed of a 1999 legacy limited sus??? Link to comment Share on other sites More sharing options...
700watts Posted December 17, 2007 Share Posted December 17, 2007 actually, I would like to know how fast you can reach the top speed of the 05 stg 1......round about 157 ? I've come close "on a closed track" but not quite.... school me please:cool: Link to comment Share on other sites More sharing options...
V4LG7 Posted December 17, 2007 Share Posted December 17, 2007 Ok so what is the top speed in a 2.5i? I've been up to 135-ish mph in my 2.5i. Link to comment Share on other sites More sharing options...
monugs Posted December 17, 2007 Share Posted December 17, 2007 Fixored! ditto! except I was on an empty stretch of Nevada freeway... Link to comment Share on other sites More sharing options...
nm Posted December 17, 2007 Share Posted December 17, 2007 ditto! except I was on an empty stretch of Nevada freeway... Not as safe as people think. NHP loves thier planes. Link to comment Share on other sites More sharing options...
limbota Posted April 23, 2010 Share Posted April 23, 2010 my brother has the outback wagon and goes 135 in that. so i think my 2.5i will easily do that. if not more. Link to comment Share on other sites More sharing options...
Mega Users LieutenantDan Posted April 23, 2010 Mega Users Share Posted April 23, 2010 Way to bump an old useless thread........ How did the mods not lock this up 3 years ago? Link to comment Share on other sites More sharing options...
Jacks GT Posted April 23, 2010 Author Share Posted April 23, 2010 Way to bump an old useless thread........ How did the mods not lock this up 3 years ago? STFU my brother has the outback wagon and goes 135 in that. so i think my 2.5i will easily do that. if not more. I don't think that your going to see a stock 2.5i outback moving that quickly. I do believe the faster you go the less accurate your speedometer is.... Link to comment Share on other sites More sharing options...
Mega Users LieutenantDan Posted April 23, 2010 Mega Users Share Posted April 23, 2010 Thanks for that. Although your insecurity got the better of you op, the information in the first couple of threads is valid. Three years old but valid. It becomes counter productive when speedboys talk about reaching top speeds on PUBLIC ROADS. Get a clue and grow up Link to comment Share on other sites More sharing options...
dr_sharp Posted April 23, 2010 Share Posted April 23, 2010 I believe only 1 person spoke of public road driving. Everyone else was talking about closed course driving. No reason to close an interesting thread because of 1 person. As wreckless and dangerous as it may be, deep down, we're all interested in knowing what is actually possible with our cars lol Link to comment Share on other sites More sharing options...
