spacejunkiehsv Posted December 7, 2007 Share Posted December 7, 2007 Is there a version of the "Three Bond 1105" liquid gasket (specified by service manual) that I can buy in an auto parts store? I called and it would be $16 for it at my dealership, which said they'd have to order a case. Edit: I misinterpreted the service manual. The liquid gasket is needed on type T differentials. Link to comment Share on other sites More sharing options...
rao Posted December 7, 2007 Share Posted December 7, 2007 Get plumbing sealant at the hardware store. It is a lot cheaper and better Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
spacejunkiehsv Posted December 7, 2007 Author Share Posted December 7, 2007 Thanks. Do you know if it is compatible with the differential oil? Link to comment Share on other sites More sharing options...
rao Posted December 7, 2007 Share Posted December 7, 2007 It is. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 7, 2007 Share Posted December 7, 2007 Is there a version of the "Three Bond 1105" liquid gasket (specified by service manual) that I can buy in an auto parts store? I called and it would be $16 for it at my dealership, which said they'd have to order a case. Edit: I misinterpreted the service manual. The liquid gasket is needed on type T differentials. The fact that they need to order a case probably means they don't use it either. They probably use a generic brand commonly available in auto parts stores. Link to comment Share on other sites More sharing options...
spacejunkiehsv Posted December 7, 2007 Author Share Posted December 7, 2007 Yeah... There are two dealerships side by side that use the same service and parts department, Chrysler/Jeep and Subaru. The buildings even look the same. They guy said they just use the Chrysler sealant on the Subaru plugs. I'm sure they don't have lots of Subaru stuff in stock, because Subarus are outsold big-time by Chrysler and Jeep down here in Alabama. Link to comment Share on other sites More sharing options...
spacejunkiehsv Posted December 7, 2007 Author Share Posted December 7, 2007 I have some ultra high temp sealant called something like "Ultra Copper" that I used for sealing a boost leak between my turbo and stock intercooler. If that is compatible with the diff. fluid, I wouldn't have to stop anywhere on the way home. Man... I'm a risk taker. Link to comment Share on other sites More sharing options...
