leggtnut Posted November 20, 2007 Share Posted November 20, 2007 So I finally replaced my JDM Spec Rev. A struts with the same kind and found that the top hats were assembled by the previous owner(s) incorrectly before. They were not seated properly and left a gap which caused the top hat to get warped. So my question now is, do I have to get the JDM tophat to replace the broken ones, or will the USDM be good. I will take pictures later if I get a chance. And if I need the JDM tophat, where would I source ones with out braking the bank. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
fweasel Posted November 20, 2007 Share Posted November 20, 2007 USDM SpecB tophats are what you need. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
leggtnut Posted November 20, 2007 Author Share Posted November 20, 2007 You want pictures? Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
fweasel Posted November 20, 2007 Share Posted November 20, 2007 I thought you were talking about the fronts. You can use your USDM stockers for the rear... same as JDM. My link above is for fronts. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
leggtnut Posted November 20, 2007 Author Share Posted November 20, 2007 they are for the fronts Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
fweasel Posted November 20, 2007 Share Posted November 20, 2007 alrighty, then click on the link in post 2. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
leggtnut Posted November 20, 2007 Author Share Posted November 20, 2007 ok . I wasn't sure if the USDM and the JDM was different and it was actually less expensive at my deliership for the USDM Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
VXCL Posted November 20, 2007 Share Posted November 20, 2007 ok . I wasn't sure if the USDM and the JDM was different and it was actually less expensive at my deliership for the USDM stearlership gonna rip you for $90. pm king of parts he sells them for about $40 i think. too bad i found out after i already picked mine up from the stealer MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
leggtnut Posted November 20, 2007 Author Share Posted November 20, 2007 That is what my dealiership wanted for them. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
