Alpinestars96 Posted November 19, 2007 Share Posted November 19, 2007 Are these just for sound? Or do they serve a purpose. Anyone have one on an automatic? Does it still sound sweet? Thanks Link to comment Share on other sites More sharing options...
rao Posted November 19, 2007 Share Posted November 19, 2007 Just sound. If you like the sound then get one, but it will not improve performance at all. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
CasopoliS Posted November 19, 2007 Share Posted November 19, 2007 I recommend not getting one as most would. Get an intake (K&N typhoon was my favorite) if you want more noise. A dowpipe adds to the orchestra quite well too. The combo makes a nice sound. The typhoon is loud though, but I liked it. That being said, you probably need a tune for that intake. At least it is a VERY good idea.. your MAF calibration will be off. Link to comment Share on other sites More sharing options...
Spec B Posted November 19, 2007 Share Posted November 19, 2007 A BOV does not improve performance at all and it probably will increase the chance of a boost leak if you do not know how to install it properly...but yes, they sound nice if you run a 50/50 of VTA BOV With that said, I still went ahead and bought a perrin recirculating BOV. Maybe it is the fact that I want to justify spending the money but I feel a little more oomph at the high end. It is not much, but enough for for it feel like it is holding boost a little better. I did some datalogs just before removing the stock BOV and I will run some logs soon and compare how well I held boost pre and post BOV install. Most likely, they will look identical..but my butt feels a lil more powa in the high end. Link to comment Share on other sites More sharing options...
CasopoliS Posted November 19, 2007 Share Posted November 19, 2007 I did some datalogs just before removing the stock BOV and I will run some logs soon and compare how well I held boost pre and post BOV install. Most likely, they will look identical..but my butt feels a lil more powa in the high end. I did this same thing with another valve and they were identical. I was probably at 19psi peak. I am not sure about performance beyond that. Link to comment Share on other sites More sharing options...
