panamajack Posted December 15, 2004 Share Posted December 15, 2004 I took the pop outs for the intake out , but they are hard to put back in. How do you put these damn things back in? Link to comment Share on other sites More sharing options...
D-2.5-GT Posted December 15, 2004 Share Posted December 15, 2004 i found it useful to slightly push in while i was turning them around....it seemed like when they found a spot they liked, it would just go right in. Link to comment Share on other sites More sharing options...
sde Posted December 15, 2004 Share Posted December 15, 2004 i hold them by squeezing in between the base and the part that pops up. then when putting them in, push on the base while keeping pressure to keep the pop-up part seperated from the base. then after it is in, a little push and twist with my thumb sets them. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted December 15, 2004 Share Posted December 15, 2004 They suck. I'm goind to tack weld some nuts under mine and use some nice stainless bolts. Link to comment Share on other sites More sharing options...
Deer Killer Posted December 15, 2004 Share Posted December 15, 2004 [url="http://www.legacygt.com/forums/showpost.php?p=69263&postcount=16"]http://www.legacygt.com/forums/showpost.php?p=69263&postcount=16[/url] Only on one part of the car have they been hard to put back, the engine cover, because the lower bracket is misaligned. Some quality time between it an some pliers makes it right. That's build quality for you. Link to comment Share on other sites More sharing options...
rao Posted December 15, 2004 Share Posted December 15, 2004 1. Take the inside part all of the way out 2. Put the outside portion in the hole 3. Insert the inside part (the part that looks like a screw head) The problem is that if you leave the inside part in the diameter is too big to fit easily through the hole. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
D-2.5-GT Posted December 15, 2004 Share Posted December 15, 2004 [quote name='rao']1. Take the inside part all of the way out 2. Put the outside portion in the hole 3. Insert the inside part (the part that looks like a screw head) The problem is that if you leave the inside part in the diameter is too big to fit easily through the hole.[/QUOTE] Are we still talking about the "plastic screws" here?? Link to comment Share on other sites More sharing options...
rao Posted December 15, 2004 Share Posted December 15, 2004 I am :) Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
S4 Posted December 15, 2004 Share Posted December 15, 2004 Yeah, I figured it out too, but only after I completely stripped the first one. Second one is beautiful. How hard is it to find these little guys to replace the one I killed? Link to comment Share on other sites More sharing options...
mwiener2 Posted December 16, 2004 Share Posted December 16, 2004 dealer can order them or has them in stock. 96 cents each, maybe less if you buy alot. My air scoop only had one in it when i got it. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
