mastabo Posted November 6, 2007 Share Posted November 6, 2007 Anyone have any ideas? I posted the same topic in general forum..but iam in the middle of installing.. My high beam does not turn on. It seems like the HIDs are flashed when i switch highbeam.(and i know i put it in the low beam with the grey cap) Also my foglights wont come on. I checked the fuse for foglights but its fine. Anyone know what is wrong? Do I have to do something after i unplug the DRL unit? I did as instructed. Link to comment Share on other sites More sharing options...
LGT Dave Posted November 7, 2007 Share Posted November 7, 2007 The procedure for disabling the DRL on the '07s is different than the previous years. Unplugging the white connector causes the highs beams and fog lights not to work. You will have to either cut the Blue Wire with the Black Stripe that goes into that plug, or you can pull that wire out of the plug if you plan on being able to easily revert it back. See this thread for more info (especially post #67): http://www.legacygt.com/forums/showthread.php?t=42292. Link to comment Share on other sites More sharing options...
msb175 Posted November 7, 2007 Share Posted November 7, 2007 yeah, they made it harder for that year. sucks. not as easy as just unplugging it. Link to comment Share on other sites More sharing options...
mastabo Posted November 7, 2007 Author Share Posted November 7, 2007 I got it now. Looks really nice. I found out after when i found that i had to cut off the blue/black wire. Thanks!! Link to comment Share on other sites More sharing options...
